Thread: Cruise Control Module
Results 1 to 19 of 19
  1. #1 Cruise Control Module
    SE Level Member midrange's Avatar
    Belleville, Ontario
    HI there,
    Bought my GP tonight. Tried cruise and didn't work, i believe it to be Module. Where is the cruise control module located? Is it hard to get at?
    My third brake light is working fine.
  2. #2 Re: Cruise Control Module
    driver side strut tower, you cant miss it.
    also check for blown fuse if you havent yet.
  3. #3 Re: Cruise Control Module
    Its easy to get to.
    It could be the module or the rest of the controls in the multifunction switch.
    If you follow the TB, one cable goes into the firewall, the other goes into cruise box.
    Where are you located? I have a known good box/cable assembly for a 97-03.
  4. #4 Re: Cruise Control Module
    Belleville, Ontario
    Quick response.. Thanks Matt, i'm in Belleville Ontario, moving to Ottawa in a month or so.. will that even work for a 2004? I'm going to first fix the solder points on the module, thats usually the culprit for failed components.
  5. #5 Re: Cruise Control Module
    Belleville, Ontario
    Thanks. Excellent.. Seems easy enough.. So far that has been the easiest location i have heard in years.. Most of the vehicles i worked on were hidden way under dash in ackward spot.
  6. #6 Re: Cruise Control Module
    Hmm, you might be out of luck there.
    Your vehicle is DBW.
    The cruise should be controlled by the DBW activation of the throttle plate.
  7. #7 Re: Cruise Control Module
    hmm, you are right matt, it is DBW, i dont know how those work.
  8. #8 Re: Cruise Control Module
    shop key suggests an 04 Grand Prix would still have a cruise control module so I would check for a fuse.
  9. #9 Re: Cruise Control Module
    Belleville, Ontario
    Well I will check the fuse.. From my past, when doing a cold solder point fix, what ever it is that controls the cruise just had bad solder points. I do not know a DBW. All I know is when I turn on the cruise, my cruise light does not illuminate which is usually a sign a a module.
    I was reviewing the book and i see there is a fuse and a relay for the cruise.
  10. #10 Re: Cruise Control Module
    Looks like there is a fuse, but no module.
    BCM, throttle actuator and PCM all communicate together.
    No cruise module.
  11. #11 Re: Cruise Control Module
    Belleville, Ontario
    hmm.. interesting. OK.. now i'm not sure what to look for. besides the fuse.
  12. #12 Re: Cruise Control Module
    Should be in the inside box.
  13. #13 Re: Cruise Control Module
    Belleville, Ontario
    So lets say that fuse is good. What would be my next step? This sounds like it could be a headache.
  14. #14 Re: Cruise Control Module
    Unsure.
    Heres this:
  15. #15 Re: Cruise Control Module
    Belleville, Ontario
    alright, according to that diagram, there is a fuse block under the hood I need to check near strut tower. It also has the display fuse.
  16. #16 Re: Cruise Control Module
    Have the car scanned for codes. In the DBW cars, IIRC nearly any code disables cruise.
  17. #17 Re: Cruise Control Module
    Belleville, Ontario
    we checked codes and I am pulling up a P0608 Code. Which is linked with the PCM i do believe.. But not exactly sure.
    If anyone has more info on that code, please let me know.
    On another note, I was incorrect, when i hit set of the cruise, the display does come up on the dash saying Cruise Set. It just doesn't drive. Just coasts.
  18. #18 Re: Cruise Control Module
    VSS output circuit.
  19. #19 Re: Cruise Control Module
    Belleville, Ontario
    VSS output circuit.
    I need to find more on the VSS. From what I am seeing, everyone is saying about replacing a wire on the VSS.. But thats more for people wanting to hook it up to their HU for auto volume. When I drive, my speedo works, my volume goes louder on the radio as I go faster.
    Dark green wire is TAC? (Throttle Actuator Control) Are these easy to fix? Could that cause the cruise not to work?
  1. Body Control Module?
    By roxie in forum General Tech Discussion
    Last Post: 06-29-2011, 12:15 PM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. cruise module needs lubrication??
    By kind153 in forum General Tech Discussion
    Last Post: 10-29-2009, 12:31 AM
