Thread: 13.8 MPG! wow....
Results 21 to 40 of 65
  1. #21 Re: 13.8 MPG! wow....
    Quincy, Mass
    dont the comp g's have 3.29 gears and get lower gas mileage? not sure if your a comp g.
    it could need a tune up, and we are on the winter mix gas wise...have you been starting the car and letting it warm up for ~10mins? get the engine light checked for free at an autoparts store. you might need a new front o2.
    dont just go by what the guy you bought it from said, he was selling you the car. you should investigate for yourself so you know whats from and make it worse.
    No more GP 04 Impala SS Indy:
  2. #22 Re: 13.8 MPG! wow....
    new britain, ct
    well you said you have a smaller pulley...i would check the tune like everybody else is saying.
    07 Black GXP.
  3. #23 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    I dont have a tuner :/
  4. #24 Re: 13.8 MPG! wow....
    Quincy, Mass
    lol your in MI theres tons of people with tuners, just ask
  5. #25 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    Cars throwing a p0135 Code, so time to replace the upstream o2 sensor ! haha
  6. #26 Re: 13.8 MPG! wow....
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    there is most likely your problem.
    1998 GTP. Stock.
  7. #27 Re: 13.8 MPG! wow....
    O2 might not be bad. I'm helping a girl chase a 0135 code on her ga and the o2 is new
  8. #28 Re: 13.8 MPG! wow....
    Feb 2009
    flintnasty MI
    99% chance this is a header leak issue.
  9. #29 Re: 13.8 MPG! wow....
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    this ^^
    The evil LG8 still refuses to die.
    Jan 2012
    N/A
    But the o2 has never been replaced in the life of the car :/ how would I know if its header leak
    Sent from my Evo
  11. #31 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    Bump
  12. #32 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    I have a 3.3 SC pully
  13. #33 Re: 13.8 MPG! wow....
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by DrSnazzy View Post
    I was getting around 25 MPG with the GTP using a 3.25 pulley and I had stock injectors. Like a lot have said, think you need a tune.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  14. #34 Re: 13.8 MPG! wow....
    usa
    check the tire pressure. mine did the same thing i now get like 5 more mpg b/c of the tires
  15. #35 Re: 13.8 MPG! wow....
    Quote Originally Posted by Brett Muszynski View Post
    Your tires would have to be flat to make you get 5 mpg worse gas mileage.
  16. #36 Re: 13.8 MPG! wow....
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    I've been getting about that much in my 2001 SE. I check for codes every month, and I haven't had any for three months. No notable power mods. It has probably been doing this for a while; this is just the first time I've taken note of the mileage and gas levels at the same time. 135 miles on 10 gallons.
  17. #37 Re: 13.8 MPG! wow....
    Cleveland Heights, Ohio, United States
    I got the same MPG right now, mainly because my damn transmission is ****ed up and it goes past the 2.5KRPM to keep up at 35 MPH which means more gas burned.
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  18. #38 Re: 13.8 MPG! wow....
    Omaha, NE
    13.8 MPG, Why?
    Because Racecar.
  19. #39 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    Does anyone have a pic of where the "Upstream" o2 sensor should be in a stock car? i want to make sure i have one lol
  20. #40 Re: 13.8 MPG! wow....
    Should be on the rear exhaust manifold. But you should have headers and then it'll be in the downpipe.
138, mpg, wow
