Thread: Gtp redux'd
Results 1 to 13 of 13
z3r0 Gtp redux'd 04-06-2011, 11:18 AM
Fivefingerdeathpunch Re: Gtp redux'd 04-06-2011, 11:22 AM
z3r0 Re: Gtp redux'd 04-06-2011, 11:32 AM
SilvaMan61 Re: Gtp redux'd 04-06-2011, 12:40 PM
TLSheff Re: Gtp redux'd 04-06-2011, 02:01 PM
z3r0 Re: Gtp redux'd 04-06-2011, 02:05 PM
z3r0 Re: Gtp redux'd 04-14-2011, 04:54 PM
z3r0 Re: Gtp redux'd 05-03-2011, 07:30 PM
z3r0 Re: Gtp redux'd 05-11-2011, 11:25 AM
TLSheff Re: Gtp redux'd 05-11-2011, 11:30 AM
z3r0 Re: Gtp redux'd 05-12-2011, 07:27 PM
Wisconsingrandprix Re: Gtp redux'd 02-06-2012, 03:23 PM
GTLGDP Re: Gtp redux'd 02-06-2012, 03:56 PM
  1. #1 Gtp redux'd
    Bunnell, FL
    okay here's ****ty night pics
    but i fixed the hud, dic and painted the wheels and arrow head black
    -- Fri Apr 01, 2011 4:04 pm --
    oh and drl delete
    -- Fri Apr 01, 2011 4:18 pm --
    some update pics....
    i'm def gonna debadge, however i'm thinking of getting the gtp badge overlays and putting them on the door in the right spots unlike my real badges are. and in reflective black. the real badges will be moved elsewhere
    i plan to debadge today....
    I'm a Sex Offender
  2. #2 Re: Gtp redux'd
    Nice job guy, its good to see the car come together.
    Did you wash the engine bay yet???
  3. #3 Re: Gtp redux'd
    Bunnell, FL
    nope. i debadged her. and i've only have her for 5 days now. i have a bit of trouble with working on car when i work since i do 10 - 12 hour shifts 4 - 6 days a week
    here's the old gtp i have 3 years ago
    Quote Originally Posted by Mr.Angry.GTP
    Didnt know ya b4, but welcome back anyways...
    trip down memory lane
    no particular order
    FWI
    pollished fuel rails
    when i spent 2500 on brakes
    i had to pwn kyle back in the day
    mmmmsexy
    eww stock
    rockers
    this will be implememnted
    i tried to make tan turn black
    pc'd grills
    cool
    sexy sauce
    i need more reflective black!
    I'm a Sex Offender
  4. #4 Re: Gtp redux'd
    MA
    awesome progress. keep it up.... wash the engine bay please
    SMGPFC Member #9
  5. #5 Re: Gtp redux'd
    I live here. TLSheff's Avatar
    Lookin better, now get it painted all the same color
    Any... could just be my opinion... but are you REALLY gonna put the GTP emblems on the inside of the doors
  6. #6 Re: Gtp redux'd
    Bunnell, FL
    maybe. who knows. i have almost 6 altogether
    I'm a Sex Offender
  7. #7 Re: Gtp redux'd
    Bunnell, FL
    cb and scanner mounted up. just need to wire everything. i have a powered speaker for the scanner, that i'll use to hear it since it's in a confined space. and i don't need it for the cb since i'll use the scanner to pick up the waves. cb is just to transmit.
    this is still pretty rough the way she sits in there. but it'll be refined more.
    but finally got the mounts worked out
    -- Thu Apr 14, 2011 5:49 pm --
    1997
    Master cylinder/fuild reservoir setup is different than on newer years
    Antenna on rear fender instead of in rear window on most 97’s
    Unique PCM for this year only, removable chip making case learn unneeded
    Large windshield washer fluid reservoir on top of battery
    Alternator and mount is different than the newer years
    Coolant temp display in the car starts at 100
    * The 97s DO NOT have tire pressure sensors. The 97s have the Delco Delphi ABS system, which could not handle the GTP power for TCS. So TCS was disabled on the 97 GTP, but works on the GT and SE. The "Tire Pressure" light was part of the Delphi ABS system; it did not sense pressure but noticed differences in tire rotation speed. When the Delphi was replace with Bosch, TCS was enabled but the "tire pressure" light was lost.
    * Some of the 97s had a prop rod instead of struts to hold up the hood. Some had under hood lights, too. The under hood lights were phased out after the prop rod, so some (few) have both struts and an under hood light.
    * Rear fender mast antennas were common for 97s because they ran out of rear window antennas at the factory. Those with mast antennas were credited $15 on the sticker.
    *Courtesy of Gene Orlanes
    Transmission input shaft is a little stronger from a better O-ring groove radius
    Complex EVAP system that uses an extra part not found on newer GPs
    M90 has an extra vacuum port
    AAA manual Passanger Seat
    AG1 Adjuster Front Seat Power
    AG6 Adjuster Front Seat Power, 6-Way, Lumbar 4-Way, Driver
    AK5 Restraint System, Front Seat Inflatable Driver and Passenger
    AP9 Net Convenience
    AR9 Deluxe Front Bucket Seat
    AT5 Seat, Rear Center Folding
    AU0 Lock Control, Remote Entry
    BA5 ORNAMENTATION, EXTR CUSTOM
    BZ7 VEHICLE GM PROD WEEK 16 GM VEH PROD WEEK 16
    B19 ORNAMENTATION, INTR, CUSTOM
    B4S MERCHANDISED PKG 'GTP' PKG 'GTP'
    B72 ORNAMENTATION, EXTR MLDG BELT REVEAL COLORED
    B90 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
    B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
    CR1 LAMP, INTR FRT DR WARNING
    C49 DEFOGGER, RR WINDOW, ELECTRIC
    C60 HVAC System, Air Conditioner Front, Manual Control
    DD8 Mirror, Inside Rear View Light Sensitive
    DG7 Mirror, Outside LH and RH Remote Control Electric, Black
    DH6 Mirror, Inside Sunshade Illuminated LH and RH
    DK6 Console, Roof Interior
    DL5 Decal, Roadside Service Information
    D55 Console, Front Compartment Floor
    D81 Spoiler, Rear Aero Wing
    E28 Assist Handle
    FAI Plant Code Fairfax, KS, USA
    FE1 Suspension System, Soft Ride
    FR2 Ratio, Transaxle Final Drive, 2.93
    IP2 TRIM,INTERIOR DESIGN (IP2)
    JL9 Brake System, Power Front and Rear Disc, Antilock Front and Rear Wheel
    KA1 Heated, Front Seat
    K34 Cruise Control, Automatic, Electronic
    K68 Generator, 105 Amp
    L67 Engine, Gas 6 Cylinder, 3.8L, Multi-Port Fuel Injected Supercharged V6
    MN7 Transmission, Automatic 4-Speed 4T65-E, Heavy Duty
    MXO Merchandised Transmission, Automatic Provisions, O/D
    NB6 EMISSION SYSTEM, CALIFORNIA, TIER 1
    NC5 EXHAUST SYSTEM, OVAL VERTICAL TAILPIPES, CHROME
    NP5 Steering Wheel, Leather Wrapped
    NV7 STEERING, POWER, VARIABLE EFFORT
    QD1 Wheel, 16 x 6.5 Aluminum
    QVG Tire, All P225/60R16-97H BL R/PE ST TL AL3
    R7K Sales Item no. 36
    R7N CONTROL - SALES ITEM NO. 39
    R9V CONTROL - SALES ITEM NO. 96
    TR9 Lamp Group
    UH8 Cluster Instrument, Coolant Temperature, Trip Odometer, Tachometer
    UK3 System Steering Wheel Accessory Control
    UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
    UT6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
    UV6 Head Up Display
    U40 Display, Digital Direct Readout, Trip Monitor
    U77 Antenna, Rear Window Radio
    VB7 BUMPER, FRONT AND REAR SPORT
    VG6 BUMPER STANDARD, LABEL, IMPACT 5 MPH
    VG8 Vehicle Label Notice To Buyer
    VK3 License Plate Mounting Package, Front
    VY7 Knob, Transmission Control Lever, Leather
    V73 Vehicle Statement USA/Canada
    WX2 SALES LEATHER APPOINTMENTS
    YF5 CERTIFICATION, EMISSION, CALIFORNIA
    Z7M MODEL CONVERSION, PONTIAC GRAND PRIX GT
    1SD OPTION PACKAGE 04
    1SZ PACKAGE OPTION
    12I INTERIOR TRIM GRAPHITE (12I)
    122 TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
    15P WHEEL COLOR SILVER METALLIC (91)
    41U PRIMARY COLOR, EXTERIOR, BLACK
    6JT COMPONENT COMPUTER SEL SUSP SUSP(6JT)
    7JT COMPONENT COMPUTER SEL SUSP SUSP(7JT)
    8FW COMPONENT RR LH COMPUTER SEL SUSP (8FW) SUSP(8FW)
    9FW COMPONENT RR RH COMPUTER SEL SUSP (9FW) SUSP(9FW)
    decoded the rpo
    anyone know what the option packages and sale items
    I'm a Sex Offender
  8. #8 Re: Gtp redux'd
    Bunnell, FL
    I'm a Sex Offender
  9. #9 Re: Gtp redux'd
    Bunnell, FL
    http://www.youtube.com/watch?v=eYXmczIcDuM
    just the zzp catback
    tried it out w/ plastidip before i took the plunge w/ bbq paint. rustoleum actually make a pretty nice product, and this is semi gloss vs flat
    here is before
    after
    i'm glad i did it this way. i was flip flopping for a few hours yesterday. but owell
    I'm a Sex Offender
  10. #10 Re: Gtp redux'd
    Just a thought, if your going to "murder" the car out, you need to tint the tails to match
    I prefer the chrome tips to the black ones, looks like there isn't any exhaust in the picture, but if you can actually see them in person it wouldn't be as bad
  11. #11 Re: Gtp redux'd
    Bunnell, FL
    my tails are already being done by flip. i had that setup the 2nd day i owned the car.
    and the tips you can see in person, its just the camera angle was a little weird.
    also flip has a bunch of stuff that he is doing for me.
    I'm a Sex Offender
  12. #12 Re: Gtp redux'd
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    nice man..
  13. #13 Re: Gtp redux'd
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Yeah tint those tails, make yours look like this one(:
    Found this on a website, looks amazing.
