Thread: So you guys might not believe this, I didnt
Results 1 to 5 of 5
  1. #1 So you guys might not believe this, I didnt
    Sep 2011
    South Central PA
    So ive been having problems with my car misfiring at high rpm: http://www.grandprixforums.net/misfi...rpm-57314.html
    I was scratching my head for about 2 weeks. I changed my spark plugs to autolite 104's and it was still acting up. So for some reason I thought maybe its those metal spark plug retainers, you know the ones that have that spring in them. So I took off those from the front 3 wires, and took a ride with my scan gauge showing my misfires in each cylinder. Well it didnt misfire in cylinders 1,3, and 5 but it did in 2,4, and 6. I then took them off the back 3 cylinders and now the car runs 100%. I couldnt believe that was the problem but my car is running great and im happy again.
    2000 Grand Prix GTP Daytona 500
    WBS PCM, 3.5 Pulley, 3'' DP into Magnaflow Hi Flow Cat, Powerlog, No resonator, Wizaraid Intake, ZZP Wires, AL 104's, 180 Stat, Poly Dogbone Bushings, Optima Yellow top battery
  2. #2 Re: So you guys might not believe this, I didnt
    Florida
    Ha I had the same problem a year ago. Turns out it was the metal sheild sparking with an exhaust manifold bolt.
  3. #3 Re: So you guys might not believe this, I didnt
    Sep 2011
    South Central PA
    Quote Originally Posted by dmahlikGT View Post
    Thats what I was thinking it could have been. I just bought the wires about a month ago. Ill contact ZZP just to see what they say.
  4. #4 Re: So you guys might not believe this, I didnt
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    wow i woulda been slightly pissed
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: So you guys might not believe this, I didnt
    Sounds like faulty wires.
    Contact ZZP, they have some special warranty going on right now.
  1. Didnt know this was down the road
    By shawnschuldt in forum Off Topic Discussion
    Last Post: 07-19-2011, 12:41 PM
  2. car didnt like to get waxed
    By valente in forum General Tech Discussion
    Last Post: 06-24-2011, 01:48 PM
  3. I didnt want to play catch
    By nyydmb12 in forum The Rant Forum
    Last Post: 09-10-2010, 02:08 PM
  4. 350z didnt want 2 race!!!
    By a98gtp4u in forum Track Sessions and Kills
    Last Post: 11-09-2009, 04:30 PM
  5. i didnt see where i could put this problem?
    By NME in forum Off Topic Discussion
    Last Post: 12-29-2007, 02:10 AM
