Thread: what size wrenches for fuel filter on a 02 GTP?
Results 1 to 18 of 18
  1. #1 what size wrenches for fuel filter on a 02 GTP?
    GT Level Member shaferz's Avatar
    Forrest IL
    Anybody know off the top of your head? I have the full Gearwrench metric set, but did not buy the SAE sizes. I would like to know what I need so that if I do not have the tool at my house, I can borrow it from my job for the night.
    99 GTP = 12.936 @ 112.12 2.16 60'
    06 TBSS = STOCK
    07 GXP = STOCK - ordering SSC's
  2. #2 Re: what size wrenches for fuel filter on a 02 GTP?
    Forrest IL
    Guess I could just plan on using adjustable wrenches.
    06 TBSS = STOCK
  3. #3 Re: what size wrenches for fuel filter on a 02 GTP?
    SE Level Member hercman's Avatar
    Marietta, GA
    spray liberally with PB blaster or liquid wrench or your favorite form of brake free quite liberally for a day or two prior to trying to remove that filter.
    1998 GTP
  4. #4 Re: what size wrenches for fuel filter on a 02 GTP?
    May 2008
    staten island,NY
    best bet is to use a line wrench like you would on the brake lines. i don't remember off the top of my head but its pretty small id say between 10 and 14mm. adjustable would just round the head
  5. #5 Re: what size wrenches for fuel filter on a 02 GTP?
    Bastard Reptile's Avatar
    Kansas City, MO
    I can't remember, since I only do it once every couple of years....but I would also recommend a line wrench. A regular one may round off the nut.
  6. #6 Re: what size wrenches for fuel filter on a 02 GTP?
    Forrest IL
    I've got some line wrenches but they are small...
    Anybody know the size?!
    06 TBSS = STOCK
  7. #7 Re: what size wrenches for fuel filter on a 02 GTP?
    PA
    Quote Originally Posted by shaferz View Post
    I am thinking 5/8" and 3/4"...but not 100% sure on that. Actually, only about 60% sure. But they are fairly large.
    2001 GSE
  8. #8 Re: what size wrenches for fuel filter on a 02 GTP?
    Donating Users
    Palatine, IL
    PM TrannyMan...he just changed my fuel filter on my Bonneville. :P
  9. #9 Re: what size wrenches for fuel filter on a 02 GTP?
    GT Level Member BackInBlack's Avatar
    Vermont
    I believe flare nut wrenches are in order...
    The GPs are long gone...
  10. #10 Re: what size wrenches for fuel filter on a 02 GTP?
    Jul 2008
    sumter,south carolina
    definately spray that thing down with PB even after i did... i had to use vise grips and beat it loose with a hammer...those nuts can tend to get very stuck.
  11. #11 Re: what size wrenches for fuel filter on a 02 GTP?
    Oct 2008
    Horsham, PA
    The fuel line size is definitely a 16mm, I am pretty sure the fuel filter size is either a 20mm or 21mm.
  12. #12 Re: what size wrenches for fuel filter on a 02 GTP?
    Oct 2008
    Horsham, PA
    I checked at work today and the hex size on the fuel filter is a 20mm. The only problem is that 20mm flare nut wrenches are NOT a popular size. I think Snap On has it for about $55, better off with vise grips or just a open end wrench.
  13. #13 Re: what size wrenches for fuel filter on a 02 GTP?
    St. Louis Mo.
    Moved to a more appropriate spot
    I will have to check my line wreches. I know I have some for my break lines, but I think 20mm as mentioned above is way to big. I think its more along the lines of 12-15mm. I will try and check today to get you a better answer.
    James Shafer
    St. Louis MO
  14. #14 Re: what size wrenches for fuel filter on a 02 GTP?
    Oct 2008
    Horsham, PA
    I just changed my the other day. It is a 16mm on the fuel line. The fuel filter itself is a 20mm. You don't need a flare nut wrench on the filter, just a wrench to hold it and keep the filter from spinning around when disconnecting or reconnecting the fuel line.
  15. #15 fuel line pressure
    SE Level Member NoTyme's Avatar
    southeast Michigan
    Quote Originally Posted by zofsharick@gmail.com View Post
    Did you have to de-pressurize the fuel line? I know some of the newer cars and trucks fuel lines are pressuruzed from the tank forward...
  16. #16 Re: what size wrenches for fuel filter on a 02 GTP?
    Banned - Busted For Scamming
    Feb 2009
    its a good idea to, just go up front under the hood where the fuel rail is and there will be a shrader valve on it, press it in to de pressurize the fuel system.
  17. #17 Re: what size wrenches for fuel filter on a 02 GTP?
    southeast Michigan
    Great!!! Thanks for the info:
  18. #18 Re: what size wrenches for fuel filter on a 02 GTP?
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    i think zef might have it.. i know one of them is 5/8.. spray the crap out of it with pb blaster for a couple days.. and tap the hell out of the nut while doing it too. it was a huge pita on my 01!!
  1. 05 Fuel Filter
    By gfdeputy2 in forum 04+ Specifics
    Last Post: 08-08-2009, 10:39 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
  4. what size filter for the wizard CAI
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-17-2008, 01:21 AM
  5. What size is the fuel pressure test port?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2008, 08:27 AM
