Thread: Traction Control making engine misfire?
Results 1 to 7 of 7
  1. #1 Traction Control making engine misfire?
    Jul 2011
    Penticton, bc
    Having a little problem with my 98 gt . The last few days we have had some heavy snow, and this morning driving to work i had a little wheel spin crossing an intersection getting out of the way of some dick head. So i hear it cut the engine out, the low trac light came on, then went off, but the car still continued to run like crap after that,. It would not idle and left me on the side of the road for 20mins . then fired the car up and it ran ok. i did have the cel on , i scanned it and got the p0300 random misfire code. So later on in the day i took it for another drive, turned the tcs off, and drove it a little hard on a snowy road to get some wheel spin to see if i could re create the misfire but couldnt with the tcs off. soon as i turned it back on, gave it some wheel spin, the low track light came on, then went off, and started running like crap. got the p0300 after that again too.. I cant locate a schematic of the tcs system. wondering if anyone has any ideas....
  2. #2 Re: Traction Control making engine misfire?
    utah
    how old are the plugs and wires
  3. #3 Re: Traction Control making engine misfire?
    SE Level Member Mad Max's Avatar
    Jan 2012
    Kentucky
    Try to keep your gas tank full in the winter. Condensation can build up in the tank and I know my car was running like crap for a while with even a fresh tune-up until someone told me to try that and it seemed to help.
  4. #4 Re: Traction Control making engine misfire?
    Jul 2011
    Penticton, bc
    i changed the plugs and wires about 2 months ago, and i always keep my car full of gas. always
  5. #5 Re: Traction Control making engine misfire?
    SE Level Member Panthers144's Avatar
    Nov 2011
    Pennsylvania
    Anything with the tachometer? dropping?
  6. #6 Re: Traction Control making engine misfire?
    Jul 2011
    Penticton, bc
    tachometer is dropping but thats because the car is running so poorly its about to die.
  7. #7 Re: Traction Control making engine misfire?
    The TCS system induces a power reduction through KR and cutting out of some cylinders to hold back power. That is understandable when you are spinning etc. Once the traction is returned and light goes out, it shouldn't continue as the pcm shouldn't be seeing a tire spinning condition.
    If you replicate the issue, then turn TCS off, does the problem go away?
  1. Traction Control ON/OFF
    By JDrach in forum General Tech Discussion
    Last Post: 11-07-2011, 12:03 AM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  5. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
