Thread: Inside lights all dim?
Results 1 to 12 of 12
  1. #1 Inside lights all dim?
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    i had aftermarket lights inside my car, they eventually started to dim so i finally ordered some new led lights thinking that my old ones were just burn out. so i put all my new ones in and same thing there all dim still? idk where i would start to look because theres obvisouly power but its not getting full juice i think.
    any suggestions?
    thanks - luke
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  2. #2 Re: Inside lights all dim?
    does this happen with the engine running?
    SMGPFC Member #10
  3. #3 Re: Inside lights all dim?
    Apr 2009
    br
    ya they get a little brighter when egine is on compared to when off...but for leds there **** and i ordered from same place i got before
  4. #4 Re: Inside lights all dim?
    there gonna be dim and flicker when the engines not running, they sure be fine with the engine running
    have you checked the sockets for corrosion? battery post for corrosion?
    SMGPFC Member #10
  5. #5 Re: Inside lights all dim?
    Apr 2009
    br
    battery is new and i dont think all the sockets are corroded .....and they are dim when engine is running
  6. #6 Re: Inside lights all dim?
    huh...maybe the leds are just bad? i running out of ideas
    whered you get them from?
    SMGPFC Member #10
  7. #7 Re: Inside lights all dim?
    Apr 2009
    br
    super bright leds.com and it happens when i plug the stock ones back in too so there's a problem somewhere but its starting to confuse me
  8. #8 Re: Inside lights all dim?
    ok so its not the lights them self
    im already confused
    so next would be alternator, fuse's, grounds, wires
    maybe something with the bcm, like its not sending enough volts to the lights
    what about the light in the glove box and visor(if you have them)
    SMGPFC Member #10
  9. #9 Re: Inside lights all dim?
    Apr 2009
    br
    alternator, fuse's, grounds, wires...that's what im starting to think.
    and glove and visor are both dim also ALL interior lights are dim
  10. #10 Re: Inside lights all dim?
    i would lean more towards maybe a ground for the bcm that came loose or got smashed or something that could mess with it
    SMGPFC Member #10
  11. #11 Re: Inside lights all dim?
    Apr 2009
    br
    ok ill look into that thanks man
  12. #12 Re: Inside lights all dim?
    Pennsylvania
    I vote ground.
  1. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  2. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  3. Inside lights. looks nice
    By Ramit888 in forum Visual/Body Modifications
    Last Post: 05-10-2010, 10:00 PM
  4. SLP Inside...
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 02:05 PM
  5. Lights inside an F1 style hood?
    By FuglyGTP in forum Visual/Body Modifications
    Last Post: 03-14-2009, 03:16 PM
