I was going to buy the mounts from the W body store because they claim they are the only ones you do not have to shim up with washers but they are so danged expensive does anyone know if this is true and is the shimming that bad to do, also the motor mount is shot I know this I have not even looked at the tranny mount but was going to order it just because the motor mount is shot and both mounts have over 300,000 miles on them or should I just leave trans mount until I check it?
What brands did you use or recommend?
Was going to follow BillBoosts how to to change them
Thanks a lot
Logan
