Thread: driver side power window??
Results 1 to 12 of 12
  1. #1 driver side power window??
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    it stoped working last summer...i figured now that its in storage it would be a good time to fix it the passenger one stil works fine, so i ordered a new motor and pluged it in and still dont work??? is there something else i should look at?
    thanks for your help
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  2. #2 Re: driver side power window??
    Ohio
    does it not work when either window switches are pressed?
  3. #3 Re: driver side power window??
    Apr 2009
    br
    im confused the passenger works when you press it on either side but drivers side dosent work
  4. #4 Re: driver side power window??
    Ohio
    the switch is bad im guessing. if you can, take off the switch, the gray part and use a tooth pick or something of the same size to push the pin inside of it with.
  5. #5 Re: driver side power window??
    Apr 2009
    br
    hmm alright guess i should have asked/tryed the swith befor i speny 80 and ripped my door apart ......thanks though man
  6. #6 Re: driver side power window??
    Ohio
    did you change the regulator too? but yeah thats the common problem whenever you cant get a window to go down or up and you know that the motor is good. coupes also, will blow a motor before a sedan too due to the window size.
  7. #7 Re: driver side power window??
    you could try to take the switch out and spray it down with electrical parts cleaner, it may work if the button still feels like its clicking when you move it.
    or the switch could be bad all together.
  8. #8 Re: driver side power window??
    Apr 2009
    br
    ya i bought the whole regulator...i think it was going bad anyways, so maybe ill just go to junk yard and pick up a new switch and try that
  9. #9 Re: driver side power window??
    Ohio
    like i said, try hitting the pin to see if thats it, or like scotty said, go to a jy and grab a new switch. a 4 door switch will work im sure so you dont have to look for a coupe.. good thing about small **** like that, easy to hide
  10. #10 Re: driver side power window??
    aka pocket parts.
  11. #11 Re: driver side power window??
    Ohio
    lol so a n* tb counts as a pocket part? cuz if so, ive bagged like 4 of them haha
  12. #12 Re: driver side power window??
    Nov 2011
    NY
    The switches are always a problem... Easy fix if you have some patience and it'll save you some $$$
    Great write up and pics to show how...
    GM Power Window Switch Copper Contacts Cleaning Guide - 1997 to 2003 Pontiac Grand Prix & W-Body Sedans Maintenance Instructions
  1. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  2. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
