Thread: HUD
Results 1 to 7 of 7
  1. #1 HUD
    SE Level Member silentkreeper95's Avatar
    Jan 2012
    Las Vegas,Nv
    I just got my car and the windshield was replaced. What can I do to the windshield so I can see my HUD?
  2. #2 Re: HUD
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Quote Originally Posted by silentkreeper95 View Post
    You should still be able to see it. My windshield was replaced with a regular one and the only time i cant see is if its really bright out. Are you sure you have the dial for the brightness turned up? or that your hud is even working at all?
  3. #3 Re: HUD
    I'm running a regular window in a regal and can see fine.
    Is it dim or impossible to see? What year?
  4. #4 Re: HUD
    Yoga city
    yes you could have hud issues, like all above have regural windshield but installed hud myself and is fine without adding tint or anything. is it a ghosting effect or the hud itself is going but likley its a photocell soilder contact point.
  5. #5 Re: HUD
    Or a broken spring on the newer hud...
  6. #6 Re: HUD
    Jan 2012
    Las Vegas,Nv
    The HUD is working because if I look at it while outside of the car of if I slouch in the seat I can see it on and working, but if i'm sitting normal I cannot see it like its not adjusting. If I play with the settings it adjusts and it even goes into stealth mode and blacks out the dash. Could it just be the spring and if so what does that cost to fix? New to these cars and don't wanna mess anything up.
    Edit: I have a 04 GTP Comp G
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Broken spring. Mine did the same thing. There should be a write up on the forum. Just search HUD fix
hud
