Thread: Engine Swap 2000 GTP
Results 1 to 4 of 4
  1. #1 Engine Swap 2000 GTP
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Ok here it goes, helped a buddy of ours swap in a 98 Park Avenue motor.. Minus a couple of changes everything went as planned. Once we got everything hooked back up. The engine wont crank, we are using the old PCM but that shouldnt matter right? At the moment the fuel pump will intermitently kick in and the car wont turn over.. Im guessing a ground problem?
    Any help would be greatly appreciated he just needs to get it back up and running....
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  2. #2 Re: Engine Swap 2000 GTP
    Nov 2009
    Grand haven
    check the gound wires that should goto the last hole in the bell on the left. There should be a stud to tighten the engine to the bell&trans then the grounds and then a nut that tightens the grounds to the stud.
  3. #3 Re: Engine Swap 2000 GTP
    Apr 2009
    stockton ca
    theres also grounds on the starter aswell
  4. #4 Re: Engine Swap 2000 GTP
    Niagara
    If the park ave motor is the same as the gp, there is a ground under the coil pack too
  1. 2000 3.1l Engine Noises
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-06-2010, 11:31 PM
  2. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
  3. 2000 SE 3.1L engine stutter
    By ejstark in forum General Tech Discussion
    Last Post: 06-30-2009, 01:03 PM
  4. 2000 gtp engine?
    By mikedinthecity in forum General Tech Discussion
    Last Post: 06-05-2009, 02:50 AM
