Thread: rough idle
Results 1 to 10 of 10
  1. #1 rough idle
    the desert
    my idle is really rough. The car shakes and the rpms go up and down rapidly at idle. Black smoke will come out of the exhaust and it smells. The car gets to the point where it sounds like its going to cut off. However it accelerates and drives fine and smooth. This happend after i had the battery out of the car for a couple of hours. Any ideas whats wrong? 1999 grand prix gtp
  2. #2 Re: rough idle
    Omaha, NE
    Is your check engine light on?
  3. #3 Re: rough idle
    the desert
    it was on. one of the codes was egr valve stuck open and the other was the maf sensor. So i replaced the sensor and the codes went away but still no luck.
  4. #4 Re: rough idle
    egr stuck open will cause prblems.
    take it off and clean it out.
  5. #5 Re: rough idle
    Omaha, NE
    Maf sensor will cause what you described.
    Was is MAF low voltage or MAF high voltage?
  6. #6 Re: rough idle
    the desert
    i took the top part of the egr valve off and cleaned that. and i dont think its the maf sensor because i put a brand new one on yesterday.
  7. #7 Re: rough idle
    Omaha, NE
    Clearly something is wrong with the MAF or you wouldn't have a MAF code.
    Was it high or low voltage?
  8. #8 Re: rough idle
    the desert
    yea im saying i did have a bad maf which threw a code. so once i got the code i switched the maf with a brand new one and the code went away. but once i switched the maf the car still had a rough idle.
  9. #9 Re: rough idle
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Check the vacuum line going into the side of the throttle body and trace it back to where it goes. I replaced my thermostat and pulled this line off the side of the throttle body to move it out of the way. When I buttoned everything up and started the car it did the exact same thing. Slide the line back on and all fixed. Yours may be cracked or the hard plactic line might be broken further down (line runs along the front of the UIM).
  10. #10 Re: rough idle
    the desert
    put all new vacuum lines in. the idle isnt as rough but its still rough. i looked at the exhaust pipes and water was dripping from them
  1. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  2. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  3. rough idle 02 gtp
    Last Post: 03-06-2010, 01:16 PM
  4. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
  5. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
