Thread: hard time starting
Results 1 to 19 of 19
  1. #1 hard time starting
    new york
    My brother ran my 2001 grand prix gtp out of gas the other night now it take a little longer to start cranks more than it did, the gauge doesn't work it follows the tach if I'm accelerating it goes to full could the pump be going? How hard is it to change these cars will u have to drop the tank and its a two door.
    Also the tach goes to zero and the tcs light has been coming on a little more often which I see is common for the crankshaft sensor to go in these cars could my problems be connected.
    Thank you
    Ohio
    You don't have to drop the tank.
    Pull the trunk lining back from the wall of the back seat, and there is an access panel to lift off.
    Hard to say what is wrong exactly.
  3. #3 Re: hard time starting
    St. Louis
    Sounds like the fuel sender is going bad. You can access the pump through the access plate in the rear of the car. Think it's in the trunk near the back seat. No need to drop the tank.
    And yes, change that crankshaft position sensor. Doubt the fuel gauge issue is being caused by the CKPS
  4. #4 Re: hard time starting
    new york
    U think by running the tank dry it hurt the pump even more it makes a very loud whinning noice sometime really really loud but it goes away u think its the sending unit making gas gauge go up and down
  5. #5 Re: hard time starting
    when you turn the key for the first time, the pump primes, thats the buzzing sound you hear, then it stops after 3 to 5 seconds.
    sounds like the sending unit went. being the gas gauge dont work.
    heres a vid. its a simple swap.
  6. #6 Re: hard time starting
    new york
    my pump would whine real loud driving down the road
  7. #7 Re: hard time starting
    new york
    wheres thhe best place to get a fuel pump
  8. #8 Re: hard time starting
    new york
    wheres the best place to get a fuel pump??
  9. #9 Re: hard time starting
    I like the napa pumps, they come with a warranty and seem to be really good quality.
    It will be alot cheaper than a dealership.
  10. #10 Re: hard time starting
    new york
    found some on ebay with warranty
  11. #11 Re: hard time starting
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    how much pressure is at the rail, should check before you spend your cash.......... it probly is your pump, i just hate wasting money on parts if i dont need them
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  12. #12 Re: hard time starting
    new york
    well my gas gauge doesnt work
  13. #13 Re: hard time starting
    Jan 2013
    Edmonton, Alberta
    hahah , thats true, i couldnt live without a gas gauge
  14. #14 Re: hard time starting
    new york
    have you heard how the ebay ones were
  15. #15 Re: hard time starting
    Jan 2013
    Edmonton, Alberta
    hhow much are they??
    2001 PONTIAC GRAND PRIX Fuel Pump
  16. #16 Re: hard time starting
    new york
    they have some from 80, and the wbody store is 100
  17. #17 Re: hard time starting
    St. Louis
    Kaw- I'd get a whole new pump/sender assembly if I were you. Since the fuel gauge doesn't work and now the pump is dead as well. No sense just replacing the pump when you will have access to the fuel sender at the same time. I actually scored an OEM GM pump/sender for my Bonneville off of Amazon for a good price. No messing w/ changing senders out, etc.. Just drop in and go.
  18. #18 Re: hard time starting
    new york
    the car still starts just sometimes it takes longer to start. the W body store has a pump but im not sure if its just a drop in i was wondering if someone could tell me.
    3800 Fuel Pumps | Fuel Pump Grand Prix, Impala, Monte Carlo, Regal
  19. #19 Re: hard time starting
    that everything in that link. new sender, and pump. its what you want. not a bad price either.
    only thing is i dont see who makes it.
  1. hard starting
    By BlackGT97 in forum General Tech Discussion
    Last Post: 12-17-2011, 08:14 PM
  2. hard starting
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 11:56 PM
  3. 98 gtp hard starting rough idle
    By 98BlknSlvrGTP in forum General Tech Discussion
    Last Post: 01-17-2011, 10:10 PM
  4. Help Car Hard Starting
    By rstark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2008, 06:24 PM
  5. Has a really hard time starting when engine is hot
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2008, 11:27 PM
