Thread: Low maintenance mods.
Results 1 to 20 of 25
  1. #1 Low maintenance mods.
    SE Level Member bentendo92's Avatar
    Aug 2008
    New Hampshire
    I'm using this thing as a daily driver and the last thing I want is for something to break because of a mod I put on the poor thing...
    SO, what would be the most simple, low maintenance mod that one could do if they intend to continue using the GP as a daily driver??
  2. #2 Re: Low maintenance mods.
    Barksdale AFB, LA
    Intake. Downpipe.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Low maintenance mods.
    Apr 2008
    Chillin at the Beach , VA
    Mufflers, headers, 3.5-3.4 pulley, and a good tune.
  4. #4 Re: Low maintenance mods.
    Moore, Oklahoma
    Most mods shouldn't require much if any maintence unless your talking an IC or something along those lines and thats easy too. I use straight distilled water spring, summer, fall and I use 50/50 coolant and water in the winter. Nothing to it really.
    Copper plugs require more changes than platnium but there worth it performance wise.
    Thats all I got...
    Shawn W. Larsen
  5. #5 Re: Low maintenance mods.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by BADAZGTP View Post
    HEADERS! Shiet thats hard to install man!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  6. #6 Re: Low maintenance mods.
    Moore, Oklahoma
    nah its not. Try installing a set on some SBCs and Mopars, you'll be thankful you're installing a set on a 3800.
    My TOGs went in flawless, no relocation of anything, no denting in primaries for various reason, etc. Only mod was the tranny dipstick tube...
    Shawn W. Larsen
  7. #7 Re: Low maintenance mods.
    Barksdale AFB, LA
    I've helped plenty of other people with their cars and I can back up Iron Indian that the W-body (especially the 3800) is pretty easy to work on in comparison. Very few stupidly placed items or bolts.
    I'm eager for the Camaro to come out so I can see how easy it will be to work on (probably not very easy, but with challenge comes experience).
  8. #8 Re: Low maintenance mods.
    Bartlett, IL
    How much do you think a shop should charge to install headers on a 3800?
    How To: E-Brake Pwn
  9. #9 Re: Low maintenance mods.
    Barksdale AFB, LA
    Quote Originally Posted by Freebeer187 View Post
    Couple hours of labor or so. That's what I'd charge (if beer wasn't offered ).
    But, my labor is usually only about $30 an hour for acquaintances.
  10. #10 Re: Low maintenance mods.
    Bartlett, IL
    Quote Originally Posted by Sabrewings View Post
    Im comin over!
    How To: E-Brake Pwn
  11. #11 Re: Low maintenance mods.
    Donating Users blowfishRus6's Avatar
    g.a.
    there not all that bad. yea it does take a little bit of time and you gotta get a little dirty but nothing major. now wait till you break bolts, have to drill them out. get the stock manifolds off, just to see that they new headers wont fit. boy was i heated. pacesetters are a tight fit on 04+
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: Low maintenance mods.
    Apr 2008
    Quote Originally Posted by blowfishRus6 View Post
    So, you finally got them on? How does the power difference feel?
  13. #13 Re: Low maintenance mods.
    g.a.
    no that was when i tried to put them on last time ill let you know how it feels when i get them on tho. plan on doing it soon
    its slow.
  14. #14 Re: Low maintenance mods.
    Apr 2008
    I see. They're that much of a pain on yours? I can probably slide mine in from the bottom, how about yours?
  15. #15 Re: Low maintenance mods.
    g.a.
    they were pushed up against the radiator fans. will at overkill told me to get some offset motor mounts and turn them backwards. that would give me the clearence i need. i think the cradle is in the way if you try to go from the bottom. it slides in good. just wont bolt up..
    its slow.
  16. #16 Re: Low maintenance mods.
    Apr 2008
    Yea, I did hear someone say something about having to do that. Might have been you telling some one else.
  17. #17 Re: Low maintenance mods.
    g.a.
    problew. i used the gaskets that came with them. they were way to big and kinda ****ty. its close with the original GM gaskets but i dident want to chance it again and figured i would wait till i knew they would fit no problem. plus under accelaration i dont want them to scrub either
    its slow.
  18. #18 Re: Low maintenance mods.
    Apr 2008
    Probably the best thing. Do it right so it don't cost more in the long run.
  19. #19 Re: Low maintenance mods.
    g.a.
    thats the goal.
    its slow.
  20. #20 Re: Low maintenance mods.
    g.a.
    plus if not. my big brother will slap me upside the head and call me a dumb ass. cause he knows hes gonna be the one to have to help me fix it
    its slow.
  1. mods for the gxp
    By miller in forum 5.3L V8 (LS4)
    Last Post: 01-13-2010, 01:34 AM
  2. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
  3. Leather seat cleaning/maintenance
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-25-2008, 09:04 AM
  4. Dodge Dakota Maintenance
    By TyroElite in forum Off Topic Discussion
    Last Post: 01-28-2008, 09:29 AM
  5. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
