Thread: Wiring fog lights to stay on with brights
Results 1 to 16 of 16
  1. #1 Wiring fog lights to stay on with brights
    Indiana
    This is relating for a 97-03, specifically a 99.
    Ok, I searched and found this thread to be sorta helpful: http://www.grandprixforums.net/fog-lights-high-beams-7318.html
    But it's lacking pictures.
    And relay 11 (ignition relay) makes me think that they will be ON whenever the ignition is on?
    This I do not want to happen. I have the DRL fuse pulled, so turning the lights on/off is all up to me using the knob.
    So, what I'm asking is if anyone has any insight to this thread or a better write up with pictures?
    Reason I'm wanting to do this is that since we put HID's in, I have nothing when brights are flipped on. So if someone else is driving the car or I have to flash lights, I don't want everything going completely dark.
    Bunnell, FL
    There is the backinblack website which.has.it. outcry its on as long ad the parking lights are on. Sorry I cant link but its a.mobile. and I'm drilynk and cant find a space bar
    Sent from my Kindle Fire
    I'm a Sex Offender
  3. #3 Re: Wiring fog lights to stay on with brights
    michigan
    ^^^wtf? Lmao
  4. #4 Re: Wiring fog lights to stay on with brights
    Indiana
    Quote Originally Posted by twol8uluz View Post
    ^^^wtf? Lmao
    x2...lol
  5. #5 Re: Wiring fog lights to stay on with brights
    Jul 2011
    NW Ohio, USA
    Quote Originally Posted by z3r0 View Post
    Translation:
    There is the Back In Black website that has the wiring you're wanting. Outcry is on there and the parking lights are on too. (I didn't quite get that part) Sorry I can't get the link but I'm on mobile. And I'm drunk and can't find the space bar.
    Sent from my Kindle Fire.
    This is the site he's referring to. BACKINBLACK's Grand Prix electrical modifications
    Owned.
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  6. #6 Re: Wiring fog lights to stay on with brights
    Indiana
    Forgive my stupidity..but I don't see a write up on there for the fog/high beams?
  7. #7 Re: Wiring fog lights to stay on with brights
    Jul 2011
    NW Ohio, USA
    LOL! I didn't either but maybe he knows something that we don't.
  8. #8 Re: Wiring fog lights to stay on with brights
    Indiana
    Back In Black did the write up in the thread I posted, but pictures aren't there and I was confused on some of the steps.
    Oh well, maybe when he sobers up he can offer some insight
  9. #9 Re: Wiring fog lights to stay on with brights
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    Looking at the schematics it looks like if you just take and cut the 86 terminal off and wire it to ground that should work ok. It looks like the fog lights would be on whenever the headlamp switch is on. If I still had my 02 I would try it and see if it worked or not.
  10. #10 Re: Wiring fog lights to stay on with brights
    Indiana
    Link to the schematics please?
  11. #11 Re: Wiring fog lights to stay on with brights
    Nov 2011
    NY
    An easier way might be to just install a switch and relay to control the fog's separate from the headlight/bright wiring altogether.
    This way, they're on when you want them independently and won't be disabled with brights... Simply take power from battery or fuse block, feed relay then feed fogs, switch controls relay. If you worry that you'll forget to turn them off, then you can use the ignition circuit for a feed to the CONTROL side of the switch, this way when car's off so are the lights. I'm not sure though what type of lights and the load on that circuit so don't quote me there.
    I remember seeing a mod that set up switches using an extra HUD switch plate (same that's on the right side) put into the left side that has same space/hole... Can't find that thread, but it's an idea for ya'.
    Just my $.02...
    try this too... my apologies for linking another forum.
    www.clubgp.com/newforum/tm.asp?m=2985451&p=5&tmode=1&smode=1&cookieCheck=6 54613812
    a
    t least to get an idea what it intended... I know it's an 04' though, sorry...
    lol... and here...
    www.clubgp.com/newforum/tm.asp?m=2700311&appid=&p=&mpage=1&key=high%2Cbeam %2Cfog&language=single&tmode=&smode=&s=#2700311
  12. #12 Re: Wiring fog lights to stay on with brights
    ankeny ia
  13. #13 Re: Wiring fog lights to stay on with brights
    michigan
    ^^yup....that cleared it all up bud!! Lol
  14. #14 Re: Wiring fog lights to stay on with brights
    Jul 2011
    NW Ohio, USA
    ^ ^ +1 for the link 35thLE
  15. #15 Re: Wiring fog lights to stay on with brights
    Indiana
    Haha. I think the 86 terminal trick would work as said by 35thLE and it shows how to in the link posted by coolone.
    What would happen if the fogs got wired into the parking lights? Would they flash with the turn signals then? (this being no beuno)
  16. #16 Re: Wiring fog lights to stay on with brights
    ankeny ia
    this should work
  1. Need help with wiring HID's fog lights
    By thegipper in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 06:43 PM
  2. LED lights wiring
    By NomeCrusher in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 01:29 PM
  3. 06 lights won't stay on
    By cooney in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2009, 07:25 AM
  4. Hit pothole..now ABS and TRAC OFF lights stay on
    By abuckley1290 in forum General Tech Discussion
    Last Post: 06-15-2009, 11:07 PM
  5. Brights & fog lights at the same time...
    By kabobulate in forum General Tech Discussion
    Last Post: 01-16-2008, 10:29 PM
