Thread: CV Joint Maybe?
Results 1 to 10 of 10
  1. #1 CV Joint Maybe?
    Dec 2011
    Detroit
    Grinding, whirring and tire lean.
    Recently, while driving I had this horrendous noise come from my driver side tire.
    I got the car home, let it sit overnight and tried to move it the next morning. Pulling straight out of my driveway it makes a grinding sound, same sound happens when I reverse straight back, Tiring is leaning in from top to bottom.
    First I thought it was a caliper but I looked at it and saw no abnormal wear on the pads or rotors, the caliper wasnt loose either.
    Im leaning towards it being the driver side CV joint.
    Any help is appreciated, Im trying to get it narrowed down before I tear into it, or pay to have someone do it.
  2. #2 Re: CV Joint Maybe?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Wheel bearing
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: CV Joint Maybe?
    wheel bearing.
    Jack up the front end ender the crossmember in the front and make sure the key is ON so the steering wheel is not locked and start shaking the tires down.
    12-6 is wheel bearing
    3-9 are ti rods.
    if you feel play, you got problems.
  4. #4 Re: CV Joint Maybe?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    its a wheel bearing.. i had hat happen to me...
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: CV Joint Maybe?
    Dec 2011
    Detroit
    wheel bearing.
    3-9 are ti rods.
    I figured it was one or the other, I had both problems on previous vehicles, they share similar symptoms but the tire lean threw me off. I've never had lean with a bad wheel bearing/hub.
    One more question though if you dont mind. lol. My "TRAC OFF" light stays on, and from what I hear thats caused by bad hubs also, or a bad connection to the plug on the back of the hub. Is this correct or should I be replacing something else?
  6. #6 Re: CV Joint Maybe?
    wheel bearing.
    3-9 are ti rods.
    3&9 could be ball joint too. Mine did that.
  7. #7 Re: CV Joint Maybe?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    how easy are wheel bearing replacements? I need one, my wheel is making a low clicking/grind noise also
  8. #8 Re: CV Joint Maybe?
    They are pretty easy the fun part is getting the wheel bearing off the cv shaft
  9. #9 Re: CV Joint Maybe?
    nut on end of thread for axle shaft + hammer = the 2 second way of getting the hub loose from the WB.
    Its just that easy.
    As for ball joints, its easier to just grab the front of the tire with both hands and move it back and forth for play.
  10. #10 Re: CV Joint Maybe?
    Its just that easy.
    I've had some that a BFH just wouldn't do I ended up having to use a pulley puller to get it out and that was on a car with only 50,000 miles.
  1. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  2. CV joint stuck?!
    By chiana4477 in forum General Tech Discussion
    Last Post: 11-17-2011, 01:29 PM
  3. cv joint question
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 05-01-2011, 03:05 PM
  4. Need gtp flex joint.
    By Dirt Diggin GTP in forum Introductions/Noob Questions
    Last Post: 08-09-2010, 11:06 AM
  5. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
