Thread: An update on my issues with my GTP
Results 1 to 6 of 6
  1. #1 An update on my issues with my GTP
    Dec 2011
    Grand Prairie, Tx
    So I got 3 codes here...
    P0336 Crankshaft Position Sensor A Circuit Range/Performance (I have a new sensor ready to install)
    P0301 Cylinder 1 Misfire Detected (Thinking its due to the Crank sensor)
    P0122 Throttle Position Sensor/Switch A Circuit Low Input (Bad throttle position sensor?)
    Your input if you got any lol, Not serious issue right? just sensors that have gone bad within the 173,000 mile life? lol
  2. #2 Re: An update on my issues with my GTP
    St. Louis
    I'd say change the crank position and TP sensor and go from there. The cyl 1 misfire could be a fouled plug, bad wire, bad coil, etc...
  3. #3 Re: An update on my issues with my GTP
    Agreed...you are on the right track.
  4. #4 Re: An update on my issues with my GTP
    Dec 2011
    Grand Prairie, Tx
    I replaced my Crank sensor and throttle sensor and today threw another code for the throttle position sensor saying low circuit yada yada yada. what the hell?!? Where the hell else could it be coming from?
  5. #5 Re: An update on my issues with my GTP
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    the wiring could have a brake
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  6. #6 Re: An update on my issues with my GTP
    I'd look over the wiring and use some electrical cleaner and spray the connections and make sure it's seated in all the way.
  1. Transmission problem Update: post rebuild issues
    By IffyG in forum General Tech Discussion
    Last Post: 07-06-2012, 12:13 PM
  2. GP Update!!!
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 02-18-2011, 01:46 AM
  3. Just an update
    By RamairGTP2 in forum Visual/Body Modifications
    Last Post: 08-01-2010, 09:16 PM
  4. nav update
    By 06blgxplover in forum 5.3L V8 (LS4)
    Last Post: 07-13-2010, 08:08 AM
  5. LIM update HELP!!!
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2009, 07:21 AM
