Thread: Yet another strange noise question!
Results 1 to 5 of 5
  1. #1 Yet another strange noise question!
    Nov 2011
    Walla Walla, WA
    NB here and need some help. I have a 06 GP std sedan. No ABS, no traction control. none of the goodies. Standard 3.8L 102,000 mi daily driver. It has what sounds like a speedometer cable noise coming from the front. Strange because I am pretty sure this car doesn't have a speedo cable. The clicking increases with speed (almost sounds like a tire seperating and flapping) and is unaffected by engine rpm. It seems to go away sometimes when I start to turn the wheel. The power steering pump is whining also so I know I need to replace that soon. I pulled the wheels (all 4) and checked brakes and for looseness (thinking hub/bearing) but all seemed ok. any ideas? I'd like to sell this thing but can't in this condition.
  2. #2 Re: Yet another strange noise question!
    Pennsylvania
    Quote Originally Posted by JackSharp View Post
    Only makes noise when the car is in motion, and changes with vehicle speed, but not wheel bearings. Warped rotor? Sticky brake caliper? Cracked swaybar?
    Check to make sure the resevoir is full, first before you just outright replace it. The cap is uncomfortably nested down next to the passenger side strut tower behind the alternator.
  3. #3 Re: Yet another strange noise question!
    Nov 2011
    Walla Walla, WA
    thanks for the PS tip. I'll do that. A cracked sway bar would make a noise like that? and change with vehicle speed?
  4. #4 Re: Yet another strange noise question!
    Kansas
    CV shaft boot ripped? Rock in wheel?
  5. #5 Re: Yet another strange noise question!
    Nov 2011
    Walla Walla, WA
    i guess i'll start replacing parts until I find it..
  1. 2007 GXP - Strange knocking noise to stump the best mechanic
    By MikeJenkins in forum 5.3L V8 (LS4)
    Last Post: 05-27-2011, 12:05 AM
  2. 2005 GTP strange noise when reving the motor
    By starscream5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 06:53 PM
  3. Strange Noise from Driver front wheel area
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2011, 05:36 PM
  4. Installed Rear ported exhaust manifolds, strange noise comeing out
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2009, 09:56 AM
  5. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
