Thread: Replaced SC coupler, bad sounds still coming from that side of the engine
Results 1 to 20 of 27
  1. #1 Replaced SC coupler, bad sounds still coming from that side of the engine
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Well i changed the coupler, got rid of some of the "marbles rolling" sound, but i still here another sound coming from the same general area of the engine. What else could be making a sound?
  2. #2 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    video?
    ima guess flex-plate or tensioner
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Houston
    A bad pulley. Did you check them when you had the belt off?
  4. #4 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Nov 2010
    Maryville, MO
    also start with belt(s) off and see if it goes away
    dont run for more than a few seconds with main belt off
    // 2005 Comp G
  5. #5 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Oct 2011
    New Jersey
    No i didn't check any of them with the belt off, i thought changing the coupler would remove all the noise. Could it be my LIM or cause my ac compressor is bad? How would i know if a pulley is bad or not?
  6. #6 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Nov 2010
    Maryville, MO
    if the noise is gone with the belt off then its a pulley or somthing driven by a pulley
    you can spin by hand, when i had a tensioner go out you could feel the ball bearings inside grinding when i hand spun it
    // 2005 Comp G
  7. #7 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Jun 2010
    ontario
    could it be that the bearings moved and now is causing the rotors to hit the casing and clunk against each other?
    in not sure if this is a possibility as someone would have to verify....
  8. #8 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Nov 2010
    Maryville, MO
    hmm you cant really mess anything up like that just doin a coupler replacement... pretty straight forward unless he pulled the impeller plate out with the rotors and when placed back together it didnt sit in the bearings on the opposite side of the housing.. he wouldnt have been able to spin the pulley aftwards with out a good deal of effort if that happened
    // 2005 Comp G
    The Boss Iceman6669's Avatar
    Jun 2011
    Umm.... Any chance of him hearing rotor slap??? As in maybe his coating is toast and the rotors are "clanking" together.
    2011 F-150 Yote powered
  10. #10 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Houston
    Quote Originally Posted by Iceman6669 View Post
    Theres a ton of things it could be....just want to make sure its not the simple stuff before tearing apart the charger.
  11. #11 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Oct 2011
    New Jersey
    The coating on the snout as a matter of fact is chipping off and in pretty bad shape. I just changed the coupler and last time i had the belt off, i spun the sc pulley when the coupler was bad to feel for bad play in it. When i changed the coupler the pulley spun nice and smooth.
  12. #12 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Nov 2010
    Maryville, MO
    well they are talking about the coating on the inside on the rotors
    and my guess is its a pulley locking up, or throwing a anger fit lol.
    and sounds like the blower is probably ok
    just need to pull the blower belt and start see if the noise is gone, if it is spin the idlers and tensioner and feel for anything thats not smooth. they are like 16 bones at autozone
    // 2005 Comp G
  13. #13 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Oct 2011
    New Jersey
    Alright ill take the belt off. Hopefully its nothing too harsh ):. How would i know when a LIM is going bad?
  14. #14 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Nov 2010
    Maryville, MO
    Quote Originally Posted by GTLGDP View Post
    any news?
    and do you mean the LIM gaskets?
    // 2005 Comp G
  15. #15 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Oct 2011
    New Jersey
    Quote Originally Posted by Austins01GP View Post
    any news?
    I guess so, and i can't do it till tomorrow when I'm back home will all the tools.
  16. #16 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    St. Louis
    I've heard waterpumps and A/C compressors make this noise as well. The A/C compressor was the louder of the 2 and much more easily noticeable.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Probably a bad tensioner
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  18. #18 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Jan 2012
    Philadelphia
    do not buy a snout until you think you know for sure whats wrong, most likely its not your snout i had the same problem. i thought it was the snout so i replaced the snout with a brand new Eaton m90 and a zzp coupler still made noise then i replaced the blower housing and rotor pack with a used one still mad noise but not as bad guessing it could be the needle bearings? im getting a blown l67 for free from my friend he says the supercharger is good so im gonna try it and throw that on. my car sounds find with the s/c belt off so im guessing its gotta be something with the s/c.. my tensoners do seem a little worn and should be replaces but i have a stethoscope and i hear the noise inside the s/c so idk i guess ill find out when i rip it apart again..
  19. #19 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Texas
    If its comig from the S/C then the needle bearings are probably shot. If the noise is still there without the S/C belt then it's possible it's the tensioner.
    85 Corvette
    01 TA
    03 Z06
  20. #20 Re: Replaced SC coupler, bad sounds still coming from that side of the engine
    Jan 2012
    Philadelphia
    yea thats what i was thinking but its hard to tell if its a tensioner on the s/c belt when that belt is off
  1. Strange Engine Sounds
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2012, 08:43 AM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. Told my Engine needed replaced!!!
    By Tammythomas68 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-06-2011, 09:18 AM
  4. Squeaky sound coming from the left side of the engine bay.
    By elhomero in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 04:03 PM
  5. Smoke coming from driver side below crossover pipe
    By millfire517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 05:17 PM
