Thread: geesh!!crank position sensor or vacuum lines or both??
Results 1 to 13 of 13
  1. #1 geesh!!crank position sensor or vacuum lines or both??
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    Ive received so much valuable advice.This problem might be from both advised repairs needing looked at.The problem it is having is that it will run fine,maybe a little hard,and out of the blue the RPM gauge will shoot down to zero(there is kinda thump or surge just before it does this).I can usually continue to drive and of course once the car is shut off and restarted the RPM gauge is back to normal.Ive been advised this would be the result of a bad crank sensor(crank shaft sensor same thing?)Ok then the other problem it has is at lower speed,usually stopping,starting,or turning a corner it has been shutting off.Doesnt do this alot,but more frequently.Ive been told by a few,including billboast this could be a vacuum line thing and that all vacuum lines should be checked.Today both of these problems converged at the same time,had the surge,rpms shot down to zero,proceeded to stop light,as it turned green and i started to turn,car cut off.Had hard time steering to stop as i guess the power steering stops when car shuts off like that.Once stopped i crank it starts right up and no more problem for the few miles home.Is this two seperate problems?
  2. #2 Re: geesh!!crank position sensor or vacuum lines or both??
    Check engine lights help...as in if the car is throwing any codes.
    Bouncing tach sounds like a crank positioning sensor...
    Vac leaks are common...and you can get the entire set from your local dealer...probably needs replacing anyways since all these cars suffer from dry rot.
  3. #3 Re: geesh!!crank position sensor or vacuum lines or both??
    Nov 2011
    portsmouth,virginia
    BLUEGT what do i ask for as far as the set of vacuum lines.Bill had said there is a vavuum line coming off the brake booster,would that be part of this set or is that a seperate vacuum hose?
  4. #4 Re: geesh!!crank position sensor or vacuum lines or both??
    that one is unlikely to leak since it is a fairly hefty, rubber line. the rest are small and get brittle when aged.
  5. #5 Re: geesh!!crank position sensor or vacuum lines or both??
    Nov 2011
    portsmouth,virginia
    Ok cool,thanks.And probably do need to have the check engine codes read,as this has been on since i got the car.
  6. #6 Re: geesh!!crank position sensor or vacuum lines or both??
    Ohio
    umm the whole vacuum line assembly is gonna run you about 60 bucks. thats what i paid for all of them to do the topswap
  7. #7 Re: geesh!!crank position sensor or vacuum lines or both??
    Any auto parts store will read them for free.
    Just drive it up there...get home...get on google and search the codes you got followed by Grand Prix...
    It'll probably pull up something Bill has typed up on here, knowing him...lol.
  8. #8 Re: geesh!!crank position sensor or vacuum lines or both??
    Nov 2011
    portsmouth,virginia
    Actually when i first got the car i did take it to ADVANCE AUTO to have codes read.Young guy came out with his little machine and within seconds told me he couldnt read codes cause my port was damaged or something.I had one guy tell me this is BS that its probably because their machines dont read the older cars.
  9. #9 Re: geesh!!crank position sensor or vacuum lines or both??
    Ummm, if the port is damaged then yeah it wouldn't read the codes...but...it is most likely user error since most places don't have parts people worth a sh1t.
    And if the SES light is on, it'll read the code...doesn't matter on how long it has been there.
  10. #10 Re: geesh!!crank position sensor or vacuum lines or both??
    Ohio
    does your cigarette lighter work by any chance? and dont give me **** about that cuz ill prove something to ya
  11. #11 Re: geesh!!crank position sensor or vacuum lines or both??
    Quote Originally Posted by 99pgpgt View Post
    I'll give you sh1t even though I know its true
  12. #12 Re: geesh!!crank position sensor or vacuum lines or both??
    Ohio
    right lol cuz i love it when people at work ***** at me cuz my scanner wont connect. i ask them if their cigarette lighter works and they say no.....so i pop out the cig lighter fuse, and sure as ****...its blown. i replace the fuse, VIOLA!!! the obd port works now o_0
  13. #13 Re: geesh!!crank position sensor or vacuum lines or both??
    Nov 2011
    portsmouth,virginia
    Well actually the cigarette lighter ports all work(theres like 3 of them,why so many i dont know)I have my IPOD plugged thru one and the phone charger in another.The guy i was talking too said that the machines they use at some of these parts stores isnt set up to read codes on older vehicles.My SES light stays on.
  1. Crank Pulley out of Position
    By marcheer in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2011, 02:43 PM
  2. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  3. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
