Re: 2005 grand prix problems
jamal313,
It is difficult to say. A few suggestions are an issue with the valve box in the transmission; another could be the mass airflow sensor. These are just suggestions, it is not a diagnosis. It would be best to take the vehicle in to be inspected by a certified technician.
Please keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
are your motor and trans mount in good shape? all the bolts went back in when you swapped it?
or is more of a slip and bang into gear?
so did they put another trans in it or what happende in this sitution?
Re: 2005 rpm going up and down
Please keep one thing in one thread. Making multiple threads makes it tougher for those that help you to keep track of everything relating to the one problem.
yeha the mechanic toped off all fluids for the car, the strange thing about this is that this issue was not even doing this when i took the car in, i had some jerks here in there while the car was moving back and forth to my destenations, and the rpm problem, but since this used trans has been put in almost at everystop of a light or anything once i i go on the gas i get this huge jerk almost everytime, i will take alook at this link, i let u know after reading, thanks
yes i do have a question, im in belleville michigan and would like to know were i could take the car for a thural check of this issue, and how would i be able to contact you
well he ijust put a used trans in, i had the mechanic checking the mounts and he said that they were good, and i will ask him about the bolt issue and its a bang, so i stop at the light and when i take off, its a huge jerk then goes
