Thread: Problems with 2006 base Grand Prix and temperature. PLEASE help
Results 1 to 4 of 4
  1. #1 Problems with 2006 base Grand Prix and temperature. PLEASE help
    Dec 2011
    USA
    I cleaned up some wires last night under the hood (grounds, power wire, etc.) and I somehow caused a huge issue. I want to stress that I changed NOTHING overall, the wires are just organized and have Tekflex on them now. The connections are all the same. What happens now is that my fans (electric) are both stuck on high and my temp gauge is stuck at zero. I feel these issues are related. The gauge still works, as it moves when I start the car.
    I replaced the coolant temperature sensor with a new one.... no effect.
    I disconnected the positive on the battery and grounded it out in order to reset all of the electrical systems... nothing.
    I disconnected the PCM in order to reset everything... nothing.
    I have no idea what to do now. The car also has sporadic voltage and it will not start due to low voltage for some reason. Maybe something is shorted? I check as many fuses as I could and saw no blown ones. And I also do not know how the battery is draining so quickly as to no allow the car to start. It will be floating at 12.8V or so, and I will start it and then shut if off and it will all of the sudden be at 12.1 V and refuses to start. The battery is in fine condition. I am sure of that.
    Thanks for any help at all?
  2. #2 Re: Problems with 2006 base Grand Prix and temperature. PLEASE help
    Omaha, NE
    Fans on high and coolant temp at zero are opposites, but it sounds like something is certainly wrong somewhere. Go back through what you cleaned and make sure no gravel or dust got between the connections, etc.
    If it was fine before, odds are something you did was the cause. No offence to you, it happens, just retrace your steps and you should find the cause.
  3. #3 Re: Problems with 2006 base Grand Prix and temperature. PLEASE help
    whats the voltage when it's idling?
  4. #4 Re: Problems with 2006 base Grand Prix and temperature. PLEASE help
    Arizona
    "I cleaned up some wires last night under the hood (grounds, power wire, etc.) and I somehow caused a huge issue. I want to stress that I changed NOTHING overall, the wires are just organized and have Tekflex on them now. "
    I'm not an auto mechanic and this may or may not be your problem but, in the statement above you said you cleaned some wires. I'm assuming you mean re-wrapped it or re-routed wires. I had a electrical issue that cropped up one day, the MAP sensor had zero voltage output. We found the wiring harness between the computer and the engine had rubbed the front valve cover until it wore a hole through the insulation. I had one broken wire and 3 exposed wires. Wondering if this maybe the same problem? Your car is the same year as mine so the possibility is there. All it takes is a short or a few broken wires to do in a computer. Hope this gives you some direction.
    Basically I am suggesting what the others have suggested, re-check your work.
  1. 05 grand prix base
    By kmk2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 04:53 PM
  2. '98 Grand Prix GT temperature issues :-/
    By hansz92 in forum General Tech Discussion
    Last Post: 07-30-2011, 02:47 PM
  3. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  4. TC on a 2006 base grand prix
    By nrfitchett4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2009, 06:06 AM
  5. 235/50-18 will these fitt base model 06 Grand Prix?
    By Shake_Zula in forum Tires & Wheels
    Last Post: 02-17-2009, 02:07 PM
