Thread: High pitched ringing sound and burning plastic smell
Results 1 to 9 of 9
  1. #1 High pitched ringing sound and burning plastic smell
    Dec 2011
    Twin Cities
    1997 Grand prix. Girlfriend called with problems. I won't be able to look at it until this weekend. I asked her if it was overheating or shifting oddly and she reported no to each. Any ideas or things to look at? Is there an alarm that rings like that?
  2. #2 Re: High pitched ringing sound and burning plastic smell
    St. Louis
    Maybe either the water pump is starting to go, or the A/C compressor is seizing up and slipping the belt. I could see how a dead bearing in one of those would sound high pitched and the buning smell may be the belt slipping across the pulley and burning it. Take a look at the underside of the belt and see if it looks glossy.
  3. #3 Re: High pitched ringing sound and burning plastic smell
    and..if she's driving it daily. Tell her to pull over at the first change or new sound. Cause that'll likely be the belt falling off.
  4. #4 Re: High pitched ringing sound and burning plastic smell
    Dec 2011
    Twin Cities
    I'll be checking the fluid levels and possibly driving it today to find out whats wrong.
  5. #5 Re: High pitched ringing sound and burning plastic smell
    Dec 2011
    Twin Cities
    FordMan nailed it. The AC compressor is seized. It sure is goofy the way things can be explained by others. So, it is pretty cold out and I don't have a lot of time. I was thinking of routing a short belt and eliminating the AC compressor until spring. Is that possible with these cars? Anyone happen to know what size belt? .
  6. #6 Re: High pitched ringing sound and burning plastic smell
    St. Louis
    I know they make a pulley to eliminate the AC, but not sure on a shorter belt. I'm sure Bill or someone will chime in with an answer.
  7. #7 Re: High pitched ringing sound and burning plastic smell
    Dec 2011
    Twin Cities
    I think I'm going to just do the eliminating pulley and get the compressor on the cheap from Rock Auto in the spring.
  8. #8 Re: High pitched ringing sound and burning plastic smell
    Unfortunately the way our path is setup, we have to run the pulley or compressor.
  9. #9 Re: High pitched ringing sound and burning plastic smell
    Dec 2011
    Twin Cities
    Had the AC compressor replaced and the system recharged. No more smells.
  1. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  2. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
  3. Getting that burning smell
    By Hockeytown19 in forum General Tech Discussion
    Last Post: 06-10-2010, 02:04 PM
  4. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  5. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
