Thread: Will a 06 GXP exhaust fit a 2001 GTP?
Results 1 to 17 of 17
  1. #1 Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    I need to replace my exhaust from the resonator back. I found someone selling a 06 GXP exhaust and was hoping it would fit my 01 GTP. Does anyone know if it will fit with or without modifications (relatively cheap modifications)? Here is a pic, can anybody tell if the radius of the bends will line up with my GTP?
    Will a 06 GXP exhaust fit a 2001 GTP? Attached Images
  2. #2 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I was wondering that too... I have a borla on my GTP and was thinking it would sound better on my GXP. I found this on summit, only one system has the same part number that I found. Let us know if you do it and of course PICTURES
    GXP
    GTP
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
    utah
    I have a buddy running a gxp cat back on his gt 2. Not sure if it was direct swap but it obviously wasent something midas couldn't handle
    tapatalking
  4. #4 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    Sounds good. Thanks for the input. I should be getting everything done next week, will let you know how it goes. Thanks
  5. #5 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    Will this option work? Get Midas to take out the broken resonator altogether, and switch out both broken mufflers to 1 magnaflow 26" glasspack on either side? So basically just all piping from the cat to the glasspack? I don't really care how the sound will be. Right now I have 2 holes in my resonator and both my mufflers are split down the welding so it is very loud right now. My main concern is not choking on exhaust fumes and not having my car sputter down the road. I'm looking at this glasspack, will it work with a 2001 GTP?
  6. #6 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Omaha, NE
    If you're going to get exhaust done, do it right the first time.
    As for the original question, its all metal, it can all be welded and bent with a pipe bender to work one way or another.
  7. #7 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    I got the car in April, it's an 01 that isn't in great shape, it has very high mileage, many problems but it is my only car. I will not spend a lot of money doing the repairs you guys would with your cared for vehicles. This car can die on me any day, until then I just want to fix the problems at the lowest cost.
  8. #8 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Omaha, NE
    Have you gotten a quote from an exhaust shop on a catback yet?
  9. #9 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    Just checked and shipping would be $98. If the total for everything was around $250 I would drive to Buffalo and get everything done there. I wanted to keep it under $200 for parts and labour. Just looking for the absolute cheapest route.
  10. #10 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    $750 for a new stock system
  11. #11 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Omaha, NE
    Wow... That's pretty steep.
    I don't know what shipping would be to canada, but zzp sells this ZZPerformance - 3" Aluminized Catback Exhaust #
    You could get 2 Thrush Turbo mufflers for around $20 each at autozone (again, that's US prices). That would put you a little over 320+ shipping. No welding required, then you could upgrade mufflers for a better sound later.
  12. #12 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    Ya I was thinking that, I just hate having to find the junk yard and then searching the lot. Some of the yards here don`t keep inventory, they just tell you to look yourself.
  13. #13 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Omaha, NE
    The only other thing I can think of would be going to a junkyard and pulling one. I'm not sure what that would cost, but could be within your budget.
  14. #14 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Charles City, IA
    For 200 you could be a glass pack put in where the res was and some pipe put in where the mufflers where. Then at least the exhaust will be going out the back.
    SMGPFC Two Nipple General
  15. #15 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    Dec 2011
    Canada
    So your saying I only need to put 1 glasspack in place of the resonator, and then just straight piping to the end where the mufflers are now? Do I put tips on the end of the pipes or just leave the 2.5" piping or whatever it is?
  16. #16 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    what you do with your tip is up to you.
    2007 Grand Prix GXP
  17. #17 Re: Will a 06 GXP exhaust fit a 2001 GTP?
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    I don't c why the gxp exhaust wouldnt fit the hangers may b an issue but thats gravy mods.
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  1. 2001 GTP SE Front Fender same as 2001 GT
    By BrentHamm in forum Visual/Body Modifications
    Last Post: 12-19-2011, 05:22 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
  4. 2001 GTP Exhaust Muffler Size
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 02:44 PM
