Thread: Comp cams 5/16" rocker bolts
Results 1 to 13 of 13
  1. #1 Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    Why are the reusable rocker arm bolts smaller then the stock TTY bolts? 5/16" vs 3/8"
    I have a 1/2" torque wrench so I got a adapter to go from 1/2" to 3/8" socket size, bought a SAE 7pc 3/8" socket set that has 3/8" as the smallest socket, then after discovered the comp cams are too small for that new socket set I just bought
    I think I used a 10mm socket on the stock TTY 3/8" bolts to get them off, it worked so what if I just use a 9mm socket for these comp cams?
    I end up using two socket adapters to make use of the 1/2" torque wrench to get them torqued right. Hopefully that 3/8" to 1/4" adapter does not snap on me when I torque to 25 ft LBs
    frankenstein might be the right term for what I am proposing
    2007 Pontiac Grand Prix
  2. #2 Re: Comp cams 5/16" rocker bolts
    comps don't use a socket.
    they use a male hex deal
    and there was a massive thread on this: extensions theoretically do not reduce torque because the torque isn't acting in the direction of the extension.
  3. #3 Re: Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    would of been nice if ZZP clearly stated the comp cams were hex bolts
  4. #4 Re: Comp cams 5/16" rocker bolts
    picture alludes to it.
    all round on the outside, with grooves to make them easier to thread by hand.
  5. #5 Re: Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    second trip to the hardware store today, they didn't have any hex 5/16th, so they order me one that should come in today hopefully
  6. #6 Re: Comp cams 5/16" rocker bolts
    Ordering a bolt or a socket?
  7. #7 Re: Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    the 5/16th hex socket that I need to torque the comp cam bolts with
    I have it now, the store had it delivered from Edmonton to the small town I live in, saved me from going to Edmonton
  8. #8 Re: Comp cams 5/16" rocker bolts
    I thought that sounded wrong so i dug out my spare set of those bolts.
    its 1/4 hex drive socket.
    5/16 is too big.
  9. #9 Re: Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    no no no no no no no wtf wtf
    this is such a pain in the ass
    you!!!!!!!!!!!!!!!!!!!
  10. #10 Re: Comp cams 5/16" rocker bolts
    Florida
    Damn man if you were closer i would lend you my 1/4 hex lol.I test fitted it to the comp cam rocker bolt just to make sure i dont have any snags.
  11. #11 Re: Comp cams 5/16" rocker bolts
    Ohio
    yeah i wish i woulda gotten to this thread earlier to tell you its 1/4....sorry bud
  12. #12 Re: Comp cams 5/16" rocker bolts
    May 2008
    Winnipeg, MB
    To end this mayhem I got a 162 pc socket set for $50 that was 70% off at Canadian Tire, it has various sized hex bits. Including of course the 1/4" that I needed. I did look in the display case to see if I could just get the 1/4" by itself but did not see it. Now I have lots of duplicate pieces but what can you do right? whatever
  13. #13 Re: Comp cams 5/16" rocker bolts
    Florida
    Better then nothin.They may come in handy one day.
  1. anyone know the install height for comp cams 105 springs?
    By WOTFTW in forum General Tech Discussion
    Last Post: 03-29-2011, 12:43 PM
  2. rocker bolts
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 08:43 PM
  3. COMP Cams 1.8:1
    By TMC in forum General Tech Discussion
    Last Post: 10-14-2008, 08:50 PM
