Thread: 2000 pontiac gtp
Results 1 to 4 of 4
  1. #1 2000 pontiac gtp
    Jan 2012
    mokena
    Hi I am new to this forum. I have an issue with my abs system. The abs light ans trac light are both on. I took it a mechanic and he said that a couple different codes came up. He said he didn't know if it was a wiring problem or if everything was actually wrong with it. I was just wonderin if any one else has had this same issue. Any if would be great. Thanks
  2. #2 Re: 2000 pontiac gtp
    Chances are you have at least one bad hub.
  3. #3 Re: 2000 pontiac gtp
    SE Level Member pontiacgtp24's Avatar
    Jan 2012
    Michigan
    I second dsmuts.take it to any competent mechanic and he'll be able to test for bearing play and noise.
  4. #4 Re: 2000 pontiac gtp
    Mercer, Pa
    What were the codes? Possible both front wheel bearings(include sensor) are bad. If they were replaced before you got the car they may have been replaced with cheap ones that only last a year or two. You may also need a pump module but knowing the codes will help with that.
  1. 2000 Pontiac Trans Am WS6
    By josemolina2008 in forum Off Topic Discussion
    Last Post: 03-01-2011, 12:02 PM
  2. 2000 Pontiac GP SE with NO OD
    By blah1919 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2010, 12:07 PM
  3. 2000 Pontiac SE :)
    By 2000segp in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 11:07 AM
