Thread: Hotwire the Fuel Pump
Results 1 to 2 of 2
  1. #1 Hotwire the Fuel Pump
    Donating Users
    Palatine, IL
    I need to drain my gas tank and want to hotwire the relay to run the fuel pump. (Trannyman suggested this as an easy option.)
    I'm assuming I could use a jumper between Pins 30 and 87 to manually run the pump. (Attached is a diagram of the FP relay under the hood.) Could someone please verify?
    Thanks
    Hotwire the Fuel Pump Attached Images
  2. #2 Re: Hotwire the Fuel Pump
    Donating Users
    Palatine, IL
    [QUOTE=TommyGloves;71077]I need to drain my gas tank and want to hotwire the relay to run the fuel pump. (Trannyman suggested this as an easy option.)
    Thanks[/QUOTE
    For future reference, jumping pins 20 and 87 will run the pump.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump??
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:25 AM
  3. fuel pump or FPR? or both?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 03:43 PM
  4. Fuel Pump?
    By 03BCprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 11:59 PM
