Thread: Dash Lights
Results 1 to 5 of 5
chuckster48 Dash Lights 12-06-2011, 10:33 PM
FordMan77 Re: Dash Lights 12-09-2011, 10:51 AM
csssaint12 Re: Dash Lights 12-09-2011, 12:17 PM
chuckster48 Re: Dash Lights 12-12-2011, 08:01 AM
chuckster48 Re: Dash Lights 12-18-2011, 08:38 PM
  1. #1 Dash Lights
    Nov 2011
    dallas, texas
    So, the red dash light behind the temp gauge is out. So, I went to my local GM shop, and tried to get a bulb. They looked around and decided they aren't available. They said the only thing they could suggest was to leave the car for several days and they would do an exchange and repair the gauge cluster and the cost would be $450.00. For a dash light, Really?????????? Any suggestion where to get a bulb?
  2. #2 Re: Dash Lights
    St. Louis
    First of all the bulb is actually clear. The cluster overlay is what's red.
    That dealer is full of sh*t. Take the cluster out yourself, pull the bulb and take it with you to any Oreilly's. I've bought them there before. Just stare and compare to make sure you have the correct one. Should run you between $3-$8 per bulb. Check the other bulbs while you have it out as there are multiple ones back there. Heck, it could just be loose for that matter.
    Just be careful of the printed circuit board on the back of the cluster where the bulbs twist and lock in as it can be easily damaged.
    Or you can bring it to me and I'll do the whole job for $225
  3. #3 Re: Dash Lights
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    OSRAM SYLVANIA - Replacement Guide - Start this chart always seems to be helpful when looking at bulb sizes.
  4. #4 Re: Dash Lights
    Nov 2011
    dallas, texas
    Thanks guys, will do.
  5. #5 Re: Dash Lights
    Nov 2011
    dallas, texas
    Thanks FordMan, and Csssaint . The job was actually easier than you described. Now I am off to other problems.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  3. Dash Lights
    By sandhj in forum General Tech Discussion
    Last Post: 04-22-2011, 05:39 PM
  4. dash lights
    By EmEaston24 in forum General Tech Discussion
    Last Post: 10-14-2009, 06:55 PM
  5. Dash Lights
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 06-15-2009, 04:01 AM
