Thread: how to fix fuel lid door
Results 1 to 4 of 4
  1. #1 how to fix fuel lid door
    Jun 2011
    Sheboygan
    I was wondering how do you fix the fuel door, it doesnt stay open when fueling, and flops arround, is there a spring of some sort to keep it shut and keep it open when fueling?
    Thanks
    1998 Red 4 door GTP
    Ported & Polished S/C with a 3.4 zzp mps
    3" catted d/p from zz
    ZZP 1.0 PCM 180 T/S CAI AL 104s
  2. #2 Re: how to fix fuel lid door
    Yup.
    Drill rivets, install new door hinge, rivet in place.
  3. #3 Re: how to fix fuel lid door
    SE Level Member wpbboy81's Avatar
    Sep 2011
    west palm beach, fl
    ^^^ what he said is probably the easy way. There's actually spring type clip in there that can be replaced. Its easily removed with just a flat head screwdriver, but a b-tch to put back in. It can be done thru the wheel well.
    98 GTP, VS cam, SD headers, 3" full exhaust (cat/resonator/ubend deleted), genV blower, 3.4 MPS, ported LIM, open cone air filter, custom tune, alternator power cable, fuel pump rewire, AL 104s, 180 stat, flipped dog bones, 04 GTP front rotors w/ F-body calipers, and the oh so comfortable monte carlo seats
  4. #4 Re: how to fix fuel lid door
    Jun 2011
    Detroit, MI
    I have the same problem, rivetssss?? Sounds complicated...
    iLoveSpade
  1. fuel door spring bad
    By hourang in forum General Tech Discussion
    Last Post: 11-20-2011, 11:06 AM
  2. fuel door bolts
    By Danalba in forum General Tech Discussion
    Last Post: 08-10-2010, 11:19 PM
  3. How do you remove the fuel door???
    By kirkkarem1212 in forum Visual/Body Modifications
    Last Post: 07-20-2010, 03:13 PM
