Thread: grand prix wont start, fuel pump is good.
Results 1 to 16 of 16
  1. #1 grand prix wont start, fuel pump is good.
    SE Level Member 1986c10's Avatar
    Nov 2011
    Kalamazoo Michigan
    Hi, i have a 97 grand prix 3.8 that i got for cheap. Car originally wouldnt hold a charge (alternator) but would start when jumped. Now after fixing that it ran good. Today after a week of sitting, the car turns over great but wouldnt even attempt to run. I pulled the fuel pump out and had it tested, sprayed gas everywhere once it got hooked up to a battery so thats good. Im gonna assume its not getting spark. Bad coils? plugs? wires? the car has a bunch of wires cut behind the cd deck and other places. none of the interior stuff works and it makes a click about 3seconds after i hit a overhead light switch or turn on the deck almost like its popping a fuse. dont know if this is related but i figured id say it. Any help would be much appreciated. Thanks guys
    1997 grand prix gt coupe dual flowmasters
    1982 chevy c10 full roller forged 355, 12 bolt rear
    1986 chevy c10 lwb no engine
  2. #2 Re: grand prix wont start, fuel pump is good.
    Sep 2011
    MI
    could be the crank sensor... these cars are kinda known for it... easy way to check is to see if you have injector pulse with a test light, and check for spark... if you don't have either its probably the crank sensor... i am assuming yiu have check all fuses?
  3. #3 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    okay wouldnt that just retard or advance the timing enough to where it wouldnt run? if thats it i'll be happy cause theyre like 10 bucks haha. Thanks for the input!
  4. #4 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    It has spark but it seems pretty weak. Is the crank sensor difficult to get to? one guy told me you have to take out the passenger wheel and suspension then remove the harmonic balancer and its behind it...
  5. #5 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    south carolina
    The crank sensor can cause no spark, but not weak spark, it's kinda a yes or no thing. You have fuel pressure at the rail and injector pulse?
  6. #6 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    weak spark is questionable but it definitely had spark. I am not sure on that, i did have moisture on the plugs after pulling them, cleaning them, reinstalling, then turning it over. I dont have a psi reading on pressure. not sure on inector pulse, could i just remove one and turn it over and make sure its spraying?
  7. #7 Re: grand prix wont start, fuel pump is good.
    Dec 2011
    Wichita, Kansas
    What you need to do is check and see if you have fuel at the shrader valve on the fuel rail. Pull the cap off let someone crank it and you press that valve down fuel should spray out. If,your second guessing that pop the air box off and spray some either into the throttle body while cranking. To check injector pulse you need a noid light. If its got spark and its cranking then it sounds definately like a fuel issue. Out of gas maybe? Sounds dumb but it happens more than you think lol
  8. #8 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    excellent advice thank you very much. when i had the fuel pump out, the tank had alot of debri in it. Im gonna assume the fuel filter may be clogged or some fuse is blown. I'll be sure to check if its getting fuel when i get out of work. Thanks!
  9. #9 Re: grand prix wont start, fuel pump is good.
    Texas
    The click you hear is the fuel pump relay coming on in the front of the car. You have a another FP relay in the back under the car. Theres a wire from it to your fuel pump. Take it off and pull it apart to check the contacts and to test it.
    I was having the same issue with my 97. Click the link in my sig if you want to read more.
    85 Corvette
    01 TA
    03 Z06
  10. #10 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    okay, the clicking happens anytime i hit anything like a door switch, cd player, overhead light etc (all of which dont work). I can hear the fuel pump running when i turn the key etc so i think the relay is fine.
  11. #11 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    i pressed the schrader valve and gas sprayed pretty good so its getting gas to the rails. it kinda stumbled and almost started when i was turning it over. My thinking is that its either getting very very very weak spark, timing is jumped, or crank position sensor is bad. Also, i hear clicking when i turn the key fully to engage the starter from the fuse box
  12. #12 Re: grand prix wont start, fuel pump is good.
    Dec 2011
    Wichita, Kansas
    Do this, this will tell you if its a fuel problem. Spray some either into the intake not alot just squirt some in their while someone cranks it over. if it starts and runs then its not getting enough fuel. Also you may pull a plug and make sure their not soaked in gas.
  13. #13 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    okay, i tried to but my can of starting fluid was empty. i'll try again tomorrow. plug was a little damp the other day when i tried. i'll inspect further tomorrow. thanks for the advice!
  14. #14 Re: grand prix wont start, fuel pump is good.
    Yoga city
    Here's my two cents fuel pump resistor?
  15. #15 Re: grand prix wont start, fuel pump is good.
    Dec 2011
    Wichita, Kansas
    I could be wrong but i have never heard of a fuel pump resistor on one of our cars.
  16. #16 Re: grand prix wont start, fuel pump is good.
    Nov 2011
    Kalamazoo Michigan
    mine is the regular l36 not the l67 and i believe only the l67 had a fuel pump resistor for the high and low speed on the fuel pump. im gonna try and get it to fire a few cylinders with starting fluid and if that works i'll test fuel pressure.
  1. need help! 05 Grand prix GT2 wont start!
    By jayetune08 in forum General Tech Discussion
    Last Post: 02-28-2011, 04:20 PM
  2. 95 grand prix with 3.1L wont start
    By montrese04 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2011, 09:23 PM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
  5. 98 Grand Prix GTP wont start...
    By keioffice in forum General Tech Discussion
    Last Post: 02-01-2010, 04:13 AM
