Thread: Rear Defrost No Workyyy
Results 1 to 5 of 5
Curt7 Rear Defrost No Workyyy 12-17-2011, 06:45 PM
Hippo Machine Re: Rear Defrost No Workyyy 12-17-2011, 06:57 PM
99PontiacGTP Re: Rear Defrost No Workyyy 12-17-2011, 09:43 PM
The Guz Re: Rear Defrost No Workyyy 12-18-2011, 12:07 AM
boostedcompg Re: Rear Defrost No Workyyy 12-18-2011, 12:40 AM
  1. #1 Rear Defrost No Workyyy
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    My rear defrost does not work. Even if i leave it on for hours lol. Any ideas what i should be looking for? 2003 Grand Prix GT
    Thanks in advance
    2003 Grand Prix GT
  2. #2 Re: Rear Defrost No Workyyy
    Jun 2011
    Detroit, MI
    check fuse first? idk
    iLoveSpade
  3. #3 Re: Rear Defrost No Workyyy
    Sep 2011
    MI
    Check to make sure there are no breaks in the grid... If there are you can buy repair kits at napa and probably any other parts store. if you have a ohm tester see if you have connection between the two tabs on the window... check for powere there too...
  4. #4 Re: Rear Defrost No Workyyy
    Dec 2008
    Lawndale, CA
    Check the tabs that connect to the window as well as the grids. One of mine broke and I bought this kit to fix it. It worked great.
    Frost Fighter Defroster Repair and Replacement Kits
  5. #5 Re: Rear Defrost No Workyyy
    utah
    That
  1. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  2. Defrost Issue
    By GreyGhost in forum General Tech Discussion
    Last Post: 12-27-2010, 10:35 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. A/C Turns on when i switch to defrost
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 08-29-2009, 10:51 PM
  5. Dual zone climate control - cannot switch modes (defrost only)
    By alacran in forum General Tech Discussion
    Last Post: 01-03-2009, 09:50 AM
