Thread: 1989 drivers door will not open
Results 1 to 5 of 5
  1. #1 1989 drivers door will not open
    Aug 2011
    mi
    1989 Grand Prix 2 door. Replaced broken driver side outer door handle. Door will not open from outside,but opens from inside. Any suggestions out there
  2. #2 Re: 1989 drivers door will not open
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    just run and slide in through the open window like Bo and Luke used to do on the Dukes of Hazzard
  3. #3 Re: 1989 drivers door will not open
  4. #4 Re: 1989 drivers door will not open
    St. Louis
    In response to the OP issue, you will have to remove the door panel and reattach the rod that goes from the outside door handle to the rest of the latch assembly as it most likely popped off. Should be a little plastic holder that the rod pops into to keep it in place. Often these break and the rod will continue to pop out of place after the outside door handle is returned to the normal position.
  5. #5 Re: 1989 drivers door will not open
    Aug 2011
    mi
    Thanks FordMan. I will Check that out. My son took the car back to college. When he comes home next month I will see if that is the problem. Thanks again
  1. Glove Box door will not open
    By lzicc in forum General Tech Discussion
    Last Post: 02-01-2017, 11:48 PM
  2. 1989 grand prix 2 door 2.8 mpfi digital dash
    By mikedinthecity in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-26-2010, 03:26 PM
  3. Door won't open.
    By jjames137 in forum General Tech Discussion
    Last Post: 03-02-2010, 09:17 PM
  4. door open
    By echarleswhyte in forum Off Topic Discussion
    Last Post: 10-11-2009, 02:27 PM
