Thread: check engine light?
Results 1 to 17 of 17
  1. #1 check engine light?
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    I was drive my 01 GP and I stepped on it hard and got up to 70 on a hill and the check engine light started flashing but stopped when I got out of the gas.Then later I got up to 100 and it started to flash. Why is it doing that?
  2. #2 Re: check engine light?
    Wichita
    Best take that car somewhere and get it scanned. When the dummy light flashes your in limp home mode. Means 'please dont drive me I'm dieing!' and you prob shouldnt until you get the issue taken care of.
  3. #3 Re: check engine light?
    Sep 2011
    Decorah IA
    It went out after a few seconds.
  4. #4 Re: check engine light?
    Wichita
    Best get it scanned asap. The codes pulled off the scanner will give you a pretty good idea where to find the prob and how to fix it.
  5. #5 Re: check engine light?
    Sep 2011
    Decorah IA
    Thanks
  6. #6 Re: check engine light?
    You have a misfire, thats why its flashing.
    Pull all the spark plugs and make sure none of them are smashed or broken, then look at your wires and make sure none are broken.
    If you dont think the plugs have been changed in a while, maybe you should just replace them all.
  7. #7 Re: check engine light?
    Per the FSM the check engine light flashes when a potential catalyst damaging condition is present.
    This typically means you have a misfire. This can be a weak coil, bad wire, bad plug or worse.
  8. #8 Re: check engine light?
    Sep 2011
    Decorah IA
    So would it only be misfiring only when im running it hard? How much is a coil?
  9. #9 Re: check engine light?
    Correct, I've had coils go out while running hard. I've also seen plug gap cause issues when running hard etc. So let's diagnose before shotgunning parts.
    Read codes and see if you have one cylinder misfire showing up.
  10. #10 Re: check engine light?
    Sep 2011
    Decorah IA
    Ok thanks!!
  11. #11 Re: check engine light?
    Wichita
    Could be bad injector orings.
  12. #12 Re: check engine light?
    Sep 2011
    Decorah IA
    I'm running STP injector cleaner when it happend and im still on that tank of gas. would that affect it. I did not have it in when I was going 100 and it happened.
  13. #13 Re: check engine light?
    SE Level Member andrewgp2000gt's Avatar
    Apr 2009
    Illinois
    i used to have this problem then i changed my 212k mile old plug wires and problem solved they would only short out under load never normal driving
  14. #14 Re: check engine light?
    Please explain.
  15. #15 Re: check engine light?
    Wichita
    Sry I'm thinking of a different problem.
  16. #16 Re: check engine light?
    Sep 2011
    Decorah IA
    1,3,5 where misfiring so time for a tune up. Thanks for the help
  17. #17 Re: check engine light?
    Sep 2011
    Decorah IA
    Finally got time to do a tuneup and the back 3 plugs where all different brands and bad lol Its all good now thanks for the help!
  1. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  2. check engine light
    By unclefester in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-18-2011, 09:33 PM
  3. Check Engine light
    By 04GTPTyler in forum Off Topic Discussion
    Last Post: 03-05-2011, 11:51 PM
  4. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  5. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
