Thread: Imp Police/Taxi Package 91C / 9C3 / 9C6
Results 1 to 4 of 4
  1. #1 Imp Police/Taxi Package 91C / 9C3 / 9C6
    Bunnell, FL
    91C and 9C3 are the police package rpo's and 9C6 is the taxi, so if your looking for certain parts it may be easier to find the taxi or just gmpp that ****, but these are all gm part number, use them to what you will
    The police sedans received the FlexFuel feature to compete against the Ford Crown Victoria Police Interceptor, which also received a similar feature allowing it to utilize E85. Also updated were the 9C1 and 9C3 trim levels for the Police Package models, which did not have the civilian SS's 303 horsepower (226 kW) V8 engine, but used the 3.9 liter (237 cu in) V6.[28] The reason being the Police Sedans utilized the SS radiator and cooling system as an upgrade from the standard 3.9 liter engine (used in the Impala LTZ). GM did not wish to design a specific radiator and cooling system to equip a low-production V8 police vehicle. Also, the heavy-duty steel wheels were not redesigned, and as such, the Police Sedan used the original center caps or the older style wheel covers. The 9C1 and 9C3 were equipped with an external trunk lock tumbler. Neither feature was available for the civilian version of the car. The 9C1 and 9C3 police models had aluminized interior trim instead of the standard wood grain.
    Radiator (1/8 Increased Tube Size and Surface Area, 1 Quart More Water) 52478255
    Aux Transmission Cooler Package
    Set Part Descriptions Part Numbers
    1-7. Hose, Tran Fluid CLR Line (W/Pipe to Aux Cooler) 10416317
    2-7. Screw, Hex W/Flat WA (Trans Fluid CLR Pipe Clip) 12337828
    3-7. Bracket, Trans Fluid CLR Pipe 10227107
    4-7. Pipe, Trans Fluid Aux (Upper from Aux Cooler) 10254586
    5-7. Nut, Hex W/Con WA 6x1x5.5 OD ZP9 (Trans Fluid CLR) 11517293
    6-7. Cooler, Trans Fluid Aux 10275682
    7-7. Bold, Hex W/FL WA, TAP, M8x1.25x20, 6202M, POR, 14.2 THD, TR FT, 24 OD (Trans Fluid CLR) 11513894
    GM Document ID: 1666160 Transmission Fluid Auxiliary Cooler Replacement
    125 Amp Alternator 10288764
    Sway Bar Package
    1-3. Front Sway Bar 10404184
    2-3. Front Bushings x2 10403188
    3-3. Front Bracket x2 10294949
    1-3. Rear Sway Bar 10274610
    2-3. Rear Bushing x2 10415925
    3-3. Rear Bracket x2 10257809
    Aux Power Steering Cooler Package
    ***** Still doing research on this ******
    1-?. Cooler, P/S Fluid Aux 26083109
    2-?. Pipe, P/S Fluid CLG (INCLS 8-9) 26081253
    3-?.
    Looking for the oil cooler numbers if anyone knows them?
    GM Document ID# 1653086 (Auxiliary Engine Oil Cooler Replacement)
    I'm a Sex Offender
  2. #2 Re: Imp Police/Taxi Package 91C / 9C3 / 9C6
    Bunnell, FL
    Trans cooler:
    One Transmission Cooler (p/n 10275682) , ACDELCO Part # 89018358 {replaces 88987267}
    -Two Nuts to Mount the Bottom of the Cooler (p/n 11517293)
    -One Hose to the Transmission (p/n 10254586)
    -One Hose from the Transmission (p/n 10416317)
    -One Bracket to Cover the Hoses (p/n 10227107)
    -Two Bolts to Mount Bracket (p/n 12337828)
    Oil Cooler:
    Gm PN# 89023443
    General info
    http://www.gmfleet.com/pdf/2010_Impala_Police.pdf
    http://www.grandprixforums.net/impal...des-30826.html
    I'm a Sex Offender
  3. #3 Re: Imp Police/Taxi Package 91C / 9C3 / 9C6
    Extended Life - Iridium Tip Spark Plugs and Wires That are Designed to Reduce Radio Frequency Noise Levels Which
    May Affect Communications Equipment Including Operating Frequencies in the 38-MHz to 58-MHz Range. The Impala
    is Designed with Unibody Construction and Multiple Grounding Points are Provided for the Vehicle Electrical System.
    No Additional Ground Straps are Added for the Police Package
    I was in some sort of service manual and police wires are 600 ohms per foot.
    non police is 3000 per foot.
  4. #4 Re: Imp Police/Taxi Package 91C / 9C3 / 9C6
    Bunnell, FL
    sweet deal thanks matt
    I'm a Sex Offender
  1. Police Package 91C Coolers etc
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 01-28-2013, 02:33 AM
  2. police package parts
    By wpbboy81 in forum Brakes/Suspension/Chassis
    Last Post: 12-07-2011, 01:48 PM
  3. Grand Prix vs Crown Vic(taxi)
    By bandits grand prix in forum Track Sessions and Kills
    Last Post: 07-28-2011, 03:12 PM
  4. Impala Police Package Upgrades
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 05-02-2010, 03:18 PM
  5. How not to get away from the police lol
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-10-2008, 09:30 PM
