I know, I do appreciate being corrected, its a good way of learning I guess. I don't know why I've always called them long blocks.
And headers yes
Can someone link me to the correct glasspack? I'm ordering two stock mufflers but i'm not sure what to get. I thought a glasspack was a muffler itself, but you guys are the smart ones not me.
it can be used as a "muffler", i did on my truck
but you'd want to judge the length for yourself, the shorter a glasspack is the louder it will be.
so i'd get the longest one you could that will fit from the catback connector to the first bend
also if your going with stock exhaust than your id and od should be 2.5" but i couldn't really tell you as i never had a stock 3800 exhaust for very long
28inch is good
Which parts from RA are the stock mufflers? I see this
AP EXHAUST Part # 700300 DIRECT FIT MSL/MAXIMUM Muffler; Direct Fit
Left; Dual Exhaust
AP EXHAUST Part # 700298 DIRECT FIT MSL/MAXIMUM Muffler; Direct Fit
Right; Dual Exhaust
or this
AP EXHAUST Part # 700293 DIRECT FIT MSL/MAXIMUM Muffler; Direct Fit
Front Muffler-; Dual Exhaust
Front Muffler-; Single Exhaust;OE system was a welded assembly. It is recommended that all parts noted [1] on INFO page should be replaced.
Junkyard some stockers...that should be cheaper
