Thread: blown engine
Results 1 to 11 of 11
  1. #1 blown engine
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    some idiot tried to tell me i had a blown motor. whats wrong with my car>? wires, plugs, coils are good. cylinder compression is good. still misfiring. what gives? i called a shop explained that and the guys said i need a new motor. thats rediculessness. car is a 99 gtp with 175k
    Smgpfc
  2. #2 Re: blown engine
    SE Level Member andrewgp2000gt's Avatar
    Apr 2009
    Illinois
    intake issues?
  3. #3 Re: blown engine
    Omaha, NE
    Bad/ Dirty Maf?
    Bad Ground?
    Bad ICM?
    Bad Fuel Injectors?
    Bad Injector O Rings?
    We need more information than "I've got a missfire". What codes are you seeing? Hows it running?
  4. #4 Re: blown engine
    Ohio
    Bad/ Dirty Maf?
    Bad Ground?
    Bad ICM?
    Bad Fuel Injectors?
    seriously. it could be alot of things but we need to know if you have codes...if so what are they?
  5. #5 Re: blown engine
    Dec 2010
    plymouth ma
    p0306. and it rruns fine, only miss's while on throttle like when getting on the highway
    Smgpfc
  6. #6 Re: blown engine
    Ohio
    Quote Originally Posted by gtcoup View Post
    cylinder 6 bud.. try swapping coil packs, injectors.
  7. #7 Re: blown engine
    Omaha, NE
    ^ This. See if it follows either a coil, a plug wire or an injector, could even just be a plug.
  8. #8 Re: blown engine
    Ohio
    i love you to brian... lol jk its brutherly pimpin sorta love
  9. #9 Re: blown engine
    Dec 2010
    plymouth ma
    yes im aware its cylinder 6. and i swapped coils from my gt. checked resistance of wires its all the same
    Smgpfc
  10. #10 Re: blown engine
    Ohio
    injector. swap it with another
  11. #11 Re: blown engine
    I'd like to keep this to one thread per issue so that we don't have to make the same suggestions again. If this isn't the case, please pm me and I'll unlock for you.
    http://www.grandprixforums.net/urgen...ire-55049.html
  1. need help with blown engine
    By jhollywood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 08:37 AM
  2. Blown 3.8
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 03:59 PM
  3. Engine Blown
    By WagZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 12:53 AM
  4. I think i'm going to get blown...
    By Tig in forum Off Topic Discussion
    Last Post: 03-29-2008, 09:03 PM
