Thread: No heat!
Results 1 to 6 of 6
  1. #1 No heat!
    SE Level Member goldcrown61's Avatar
    Indiana
    I have a 2008 Grand Prix. I have noticed the last year the heat coming out of the vent is luke warm. when I accelerate it gets warmer but at idle it cools off again. I have 73,000 miles on it. Is it time for a flush?
  2. #2 Re: No heat!
    I would flush the coolant, and pop in a new thermostat (195*).
  3. #3 Re: No heat!
    Indiana
    I will give that a try and let you know the results. Thanks for the reply!
  4. #4 Re: No heat!
    Indiana
    Well, I had the system flushed and thermostat replaced. Now that winter is here I am still at square one. Someone told me it could be the temperature control valve?
  5. #5 Re: No heat!
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Do a complete system flush and then do a reverse flush through the heater core. Blast a hose through both the things of the heater core. Make sure u have clean and the same amount of pressue coming through both ends. Then u should be good.
    What happens is when u take off, the water pump pumps more pressure through and that's y its warmer until u slow down. Then its not pumped as hard and fast.
  6. #6 Re: No heat!
    Indiana
    Thanks for the advise. I will give that a try and let you know what happens.
  1. heat not hot
    By onetyme77 in forum General Tech Discussion
    Last Post: 02-02-2011, 06:43 AM
  2. Heat???
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 12:44 AM
  3. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  4. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
