Thread: What if my DIC is acting up?
Results 1 to 8 of 8
  1. #1 What if my DIC is acting up?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    Its not totally a big deal but the DIC is not working properly on this car either.The range indicater for the gas and other functions will just bounce numbers at me.Sometimes low number,next minute high number.(it will say im at 65 range but five minutes later it will say 329).Sometimes it will tell me that the fuel is low even though i just put fuel in it,than it will bounce back to a high number.Or the low fuel will show up on screen but if you drive abit or cut car off the low indicator will disapear.The digital car does show you when doors and trunk are open.Hit the reset and that does nothing.So the bottom line is it seems some functions work and some arent.What should i do?
  2. #2 Re: What if my DIC is acting up?
    Omaha, NE
    So all the problems you are having are fuel related?
    If so you probably need a new fuel level sensor.
  3. #3 Re: What if my DIC is acting up?
    Nov 2011
    portsmouth,virginia
    So the DIC is also tied into the low fuel sensor?You know from my other post that the fuel level indicator on the cluster is acting weird too.The reset button does nothing on mine.I was wondering if this thing works independently from the computer.What would happen if you disconnected it?
  4. #4 Re: What if my DIC is acting up?
    Omaha, NE
    If you disconnected what?
    The sensor is going to be tied into both the dic and the cluster. Your car bases range on how much you have left/ your average or instant mpgs. The sensor should be about $25 new.
  5. #5 Re: What if my DIC is acting up?
    Nov 2011
    portsmouth,virginia
    Well i was saying disconnect the DIC.From what i read it simply unplugs from the back.If it is the sensor and that solves issue well that would be prefered.However still doesnt explain why the reset button does nothing.By the way is that low fuel sensor in the gas tank? It was in another car i had repaired.
  6. #6 Re: What if my DIC is acting up?
    the dic and gauge go by the sensor in the tank.
    Is the gauge reading funny, like going from full to empty all the time too or just the DIC?
  7. #7 Re: What if my DIC is acting up?
    Nov 2011
    portsmouth,virginia
    Both are acting up.so i guess a new sensor is in order.
  8. #8 Re: What if my DIC is acting up?
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    My gtp does the same thing, but the fuel guage bounces around, which makes the DIC go all whacky. Bad fuel sending unit I believe. I just count the miles per full tank with the trip computer.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  1. 3.8 N/A acting funny
    By Pontiac Cali Guy in forum General Tech Discussion
    Last Post: 04-07-2011, 11:00 AM
  2. Electronics acting up in the GP
    By l3enner in forum Audio, Security & Visual Electronics
    Last Post: 07-29-2009, 08:18 PM
  3. GTP Acting up.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 08:56 AM
  4. GTP is acting up PLEASE HELP!!!
    By azmattaz06 in forum General Tech Discussion
    Last Post: 02-14-2009, 02:30 AM
  5. 98 GTP acting up help!!!!!!!!!
    By Red_GTP in forum General Tech Discussion
    Last Post: 08-04-2008, 05:35 AM
