Thread: Temp guage
Results 1 to 10 of 10
  1. #1 Temp guage
    GTP Level Member
    Nov 2011
    Kansas
    I replaced my battery today, and now the temp guage isnt working. The guage itself still does the full sweep on start up, but doesnt display reading. Any ideas?
  2. #2 Re: Temp guage
    Omaha, NE
    Coolant Temp Sensor is probably bad or has a bad connection.
  3. #3 Re: Temp guage
    GTP Level Member
    Nov 2011
    Kansas
    On a day I have time I will have to check all those connections over there. The heater is still working so I dont think it is the thermostat. I quickly checked connections and they seemed good, but that was a very fast check before work.
  4. #4 Re: Temp guage
    GTP Level Member
    Nov 2011
    Kansas
    I checked all the connections in that area and everything was good. And the gauge still isnt working.
    After looking around and talking to some people, I am thinking it may be the coolant sensor, which is a cheap fix, just looks like coolant will get everywhere.
  5. #5 Re: Temp guage
    Nov 2011
    south carolina
    Quote Originally Posted by develand View Post
    Have the new part right there, ready to go. Keep your pressure cap on, keep the cooling system sealed. When you pull the old sensor out, thread the new one in quick. You might be surprised on how little coolant comes
  6. #6 Re: Temp guage
    Drain 3/4 of a gallon of coolant. Change sensor, refill. No mess no fuss
  7. #7 Re: Temp guage
    Minnesota
    Let me guess. You have an 04+ Grand Prix?
    If so. I would try going to a parts store and having them clear the codes in the PCM and see it that does anything.
    This happened to an 04 GP GT at a local meet after someone tuned it. I hooked up my scanner and deleted the codes in the PCM and it came back on. Don't know why but it did. lol
  8. #8 Re: Temp guage
    GTP Level Member
    Nov 2011
    Kansas
    Got in this morning and it was working..... Odd
  9. #9 Re: Temp guage
    Minnesota
    Is your car an 04+ GP?
  10. #10 Re: Temp guage
    Mar 2012
    Buffalo
    My car is having this issue after I looked in my fuse panel, still trying to find out which fuse is the issue.
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. Trans Temp guage question
    By Kenny75k in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2010, 04:38 PM
  3. 04 GTP Temp Guage Quit Working
    By trick94cobra in forum 04+ Specifics
    Last Post: 11-11-2009, 09:07 PM
  4. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  5. Manifold Air Temp Guage?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 05:24 PM
