Thread: cold start help needed
Results 1 to 10 of 10
  1. #1 cold start help needed
    Donating Users onetyme77's Avatar
    texas
    i have a 98 gt n/a, its been sitting since the summer at my grandmother house in another state, the battery went dead and she has not started it since i left it. she going to have a battery put in, is there any type of start up procedure i need to tell her about? like a fuel or oil additive ? any input would help thanks
  2. #2 Re: cold start help needed
    Jun 2011
    Detroit, MI
    Not really, I mean if it won't start, try pushing the pedal a couple times, but if you flood the engine with gas, let it sit for a bit and try again. Just make sure it warms up a bit before driving it, so the oil and lubricate all the parts again.
    iLoveSpade
  3. #3 Re: cold start help needed
    Omaha, NE
    Gas only lasts about 3 months before it starts to break down. There's nothing you can do about that at this point, it's going to run like crap until it's all out.
    The oil should be alright, but I would get it changed asap.
    Why the new battery instead of a jumpstart?
  4. #4 Re: cold start help needed
    texas
    isnt there something you can add to the fuel if it has been sitting for a while?
  5. #5 Re: cold start help needed
    if she can check the oil, do that, and just let it idle, don't gas it for a while, idle it for 5 to 10 minutes so the oil gets pumped back through the engine. you should be ok.
    have her at least start it up once a week, if it can be driven, do have her ride it to the store once in a while, keeps the brakes from rusting to hell. add stable to the gas tank too, if it fires up on the old gas.
  6. #6 Re: cold start help needed
    Omaha, NE
    Quote Originally Posted by onetyme77 View Post
    Stabil, but the fuel is already broken down, so it will do no good. You should have put it in before you left the car sitting.
  7. #7 Re: cold start help needed
    texas
    man i dont know, im in Texas they are in Louisiana, I know that battery is old, she said she tried to charge it and that my grandfather tried to jump it, so idk it needs a new battery any way
  8. #8 Re: cold start help needed
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by Hippo Machine View Post
    0_o
    You do realize it is NOT carb right...
    2011 F-150 Yote powered
  9. #9 Re: cold start help needed
    texas
    i didnt plan on it jus sitting this long, she waited a good while before she tried to start it. i cant get to it till january so ima send the money for the battery and relay this info to her or grandfather
  10. #10 Re: cold start help needed
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Iceman6669 View Post
    0_o
    Mine is.
    Oh wait..
    iLoveSpade
  1. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  2. Stumble on cold start
    By RotyP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2011, 10:32 PM
  3. 88 GP stalls when hot & won't start again until cold
    By MarkUSAF in forum General Tech Discussion
    Last Post: 08-02-2011, 04:38 AM
  4. Cold Start Hissing
    By SuperSport in forum General Tech Discussion
    Last Post: 07-24-2009, 12:56 PM
  5. HELP NEEDED Engine will not start
    By jimcarey78 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-02-2008, 03:01 PM
