Thread: Best way to clean LIM & supercharger gasket surfaces?
Results 1 to 4 of 4
  1. #1 Best way to clean LIM & supercharger gasket surfaces?
    Cambridge, Ontario Canada
    I have used carb cleaner, degreaser etc.. and a razor blade. The surface feels smooth for the most part but there is still a gasket discoloration or residue left over. How do I get the surface perfectly clean? I was thinking of using a wire wheel but don't want to destroy anything.
    Suggestions?
    2005 E55 - stock
  2. #2 Re: Best way to clean LIM & supercharger gasket surfaces?
    i used a wire wheel on mine and it seals up fine
  3. #3 Re: Best way to clean LIM & supercharger gasket surfaces?
    Omaha, NE
    The strongest chemical to use would be aircraft stripper. I gently used a pneumatic sander at my friends shop to skim the surface on mine last time I did them. That worked great.
  4. #4 Re: Best way to clean LIM & supercharger gasket surfaces?
    FWIW I use a 3m roloc pad like most mechanics. The surface appears clean until I wipe it clean with brake cleaner. The gasket shadow appears again when it's cleaned. That's completely normal and doesn't mean that the surface is not clean.
    What I'm saying is..I think you are all set.
  1. Supercharger gasket
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 03:48 PM
  2. Supercharger Gasket
    By Spazztic2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-17-2010, 02:47 PM
  3. Clean a Supercharger?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 09-27-2009, 10:02 PM
