Thread: what are the screw plugs on the back of door panel called?
Results 1 to 7 of 7
  1. #1 what are the screw plugs on the back of door panel called?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    I only have a few of these little plastic screws holding my door panel onto the door thus not the tightest of fits.What are these little pieces called(they are white)? Where can i get more? Do you think junkyard might have some are should i get new ones?
  2. #2 Re: what are the screw plugs on the back of door panel called?
    Omaha, NE
    Are you talking about the body pins between the door panel and the door?
    Any parts store should have them new in bulk (I think they are packages of 12), I know every autozone I've been in does.
  3. #3 Re: what are the screw plugs on the back of door panel called?
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Door panel clips? just tell whoever you go to that you want the white pins that hold the door panel to the door. they'll know what your talking about
  4. #4 Re: what are the screw plugs on the back of door panel called?
    Nov 2011
    portsmouth,virginia
    Door panel clips..ok thanks...and i can get them at autozone....cool.
  5. #5 Re: what are the screw plugs on the back of door panel called?
    Waukesha, WI
    make sure you get GM ones,
    i went to autozone and asked for them and they gave me the chysler style,
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: what are the screw plugs on the back of door panel called?
    Never Never Land
    Push pins...mine came in a box of 15...if both doors need done get 2 boxes...theres like 13 per door
  7. #7 Re: what are the screw plugs on the back of door panel called?
    Nov 2011
    portsmouth,virginia
    Thanks for the help.The passenger door is fine,its the driver door.Who ever owned it before me had taken it apart to get to the speaker,my friend helped me replace the speaker recently,there were like only six of those pins left so he did the best he could spreading them out.
  1. Back lit gxp trunk panel / bonniville set up
    By jarheadbobandmax in forum Visual/Body Modifications
    Last Post: 11-01-2010, 10:03 AM
  2. door panel
    By witnessprotections in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 01:38 PM
  3. door panel
    By kittie1342 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-26-2009, 07:54 PM
  4. Door panel
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 02:26 PM
