Thanks for the code breakout...I was on my way to the dealer, who doesnt list an HDM, like Ive heard about on this and other forums. Is the Lo-Beam relay the same thing? Thats all the dealer listed for headlamps; lo-beam and Hi-beam relays...Anyway, I was on the way to the dealer and noticed my headlamps are working again. Obviously the relay isn't out like a fuse. Can they start to go out and work intermittently, or was it more likely just loose?
Should I go ahead and get it now?
The relay can definitely work loose. I had it happen to me. I was driving down the highway and , BAM, low beams went out. I switched to hi beams and they worked. I got to the next exit and pulled into a parking lot and they magically started working again. Low beams went out on me 2 times after that at random times. I popped the lid to the relay box and pulled the low beam relay, reseated it, and have no had the issue since.
