Thread: Another Blower Motor Question.
Results 1 to 20 of 22
  1. #1 Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    Ok. I am new to your site but not to forums. I did some reading yesterday and did not find what I am looking for. I will make this as shot and to the point as i can.
    I just purchased a 1998 Grand Prix. Got it at a good price since the blower motor is not working any speed.
    Here is what i have done so far.
    1. New Blower motor.
    2. New Blower motor module <-- Yes Module. part # 52479971. Please see pic.
    http://l458.com/misc/BlowerMotorModule.jpg
    3. New Starter switch and wiring harness.
    4. Cleaned ground connectors.
    5. New Head unit. <-- old and new work the same
    6. Fuses are good.
    Ok. after all this the blower motor will now run but only runs on #1 & #2 setting. If i go up any higher the motor will cut on and off a few seconds then stop all together. I have checked the wiring harness for cut wires and also found no defects.
    Well Obviously i am missing something. My only other guess is I have another bad Blower motor module. But before i go out and spend another $120.00 for this part I thought would pick you brains.
    BTW, all the sites i have gone to, None of them show this module. they are all totally different.
    Any help is much appreciated.
    Another Blower Motor Question. Attached Images
  2. #2 Re: Another Blower Motor Question.
    Oklahoma
    Its either the blower motor resistor, or the ignition switch. Ive never seen that module before so I suppose that could be the resistor module but it sure doesnt look like any of them I have seen before.
  3. #3 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    Bran new Blower motor, ignition switch, Head control unit, and Blower motor module.
  4. #4 Re: Another Blower Motor Question.
    GrandPrix Junkie
    Saraland Alabama
    Sure sounds like resistor, mine was $20 looks like the one you got was a ton more. The resistor controls the speeds
  5. #5 Re: Another Blower Motor Question.
    May 2008
    Downriver, MI
    Agreed it's more than likely the "Blower Motor Resistor". I did this a few weeks back. I got mine from autozone for like $16 bucks or something like that.
  6. #6 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    Ok,
    Please see the attached image. My car does not have the blower motor resistor. It has this blower motor module. It mounts in the same place as the blower motor resistor.
    Its 100% factory.
    My part # is delco 15-8756 GM part 52479971
    all the books and sites show the resistor of
    delco 1580571 gm # 1213102 and several other.
    The chiltons and Hays books also do not show my set up.
    I am stumped.
    Please advise were the "Resistor" will be located. Cause if it is in the Blower motor housing thats not it.
    Thanks again for your help.
  7. #7 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    Hope my last post did not come across rude. If it did i apologize. I am at work and was typing fast.
    I think i am going to research changing the Control unit wiring harness also as everything else is new.
  8. #8 Re: Another Blower Motor Question.
    Oklahoma
    Nope, not rude at all. Ive seen much worse. I would have to say then you have a very different beast because I have never seen that module before. Ive replaced my blower motor resistor too and did not see anything like that around there.
    So to me that leaves the ignition switch if indeed that module takes the place of the resistor pack.
  9. #9 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    FYI.
    Ignition switch is new also.
    Just got off the phone with Pontiac. I will have to say my idea of replacing the harness is dead since they just told me this belongs to the main harness. I did not call around yet to find one cheaper but he told me $2800.00. Nope, Nope, Nope,
    Back to the drawing board. May have to break down and buy a new Blower Control Module.
    ack!
  10. #10 Re: Another Blower Motor Question.
    Apr 2008
    Chillin at the Beach , VA
    Quote Originally Posted by darylward View Post
    FYI.
    ack!
    Do you have anyone there, a friend or someone that has a GP like yours? If so see if you can swap the part with theirs and see if theirs does the same thing. Just a thought.
  11. #11 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    I dont know anyone that has a car like mine.
    I feel i have covered all bases, i will see about checking the wiring harness as best as i can before buying and testing a new part. I was just hoping i missed something like a hidden relay, switch, or fuse. Usually when I get stuck like this it ends up being a real big PITA.
    Daryl.
  12. #12 Re: Another Blower Motor Question.
    Oklahoma
    I just now realized you were from Kissimmee, FL. Im originally from the Lake County area.
  13. #13 Re: Another Blower Motor Question.
    Apr 2008
    In a previous post, he said that he's replaced evryting including the ingnition switch. Starting to sound like something in the wiring maybe. But still wouldn't rule out a faulty part. It does happen from time to time.
  14. #14 Re: Another Blower Motor Question.
    Oklahoma
    Crap, I completely missed that, I apologize for that.
  15. #15 Re: Another Blower Motor Question.
    Apr 2008
    I'll see if I can do a little digging on it more also and see if I can find anything else that might be getting over looked.
  16. #16 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    Welp,
    Opened up the dash and removed the glove box again. Checked and could not locate a short, "Will try again" Took every fuse out cleaned and check. Removed the main wire harnes block and cleaned every pin, & also removed and cleaned the main ground wire from the fuse panel under the hood.
    I have rebuilt some water damaged car easier then this. grrrr.
    Appears i will be purchasing a new Blower module just to be sure.
  17. #17 Re: Another Blower Motor Question.
    Oklahoma
    I dont know for sure, but you might ask if the parts store has a means to test the thing and check it, might save some hassle if they can.
  18. #18 Re: Another Blower Motor Question.
    GrandPrix Junkie
    Saraland Alabama
    when I looked your car up it listed the resistor
    BWD Automotive A/C Blower Motor Resistor
    Part Number: RU867
    BWD Automotive A/C Blower Motor Resistor:
    Part Number: RU867
    This product fits the following vehicles - click on a vehicle to see detailed engine information.
    BUICK back to top
    1997 - 2005 CENTURY
    1997 - 2004 REGAL
    2005 LACROSSE
    CHEVROLET back to top
    1997 - 1999 CORVETTE
    2001 LUMINA
    2001 - 2002 CORVETTE
    2000 - 2005 MONTE CARLO
    2001 - 2005 IMPALA
    1997 - 2000 VENTURE
    OLDSMOBILE back to top
    1998 INTRIGUE
    1997 - 2000 SILHOUETTE
    2000 - 2002 INTRIGUE
    PONTIAC back to top
    1997 - 2003 GRAND PRIX
    1997 - 1998 TRANS SPORT
    1999 - 2000 MONTANA
    it's the one I put in my car 3 years ago.
  19. #19 Re: Another Blower Motor Question.
    Aug 2008
    Kissimmee Fl
    My part number is
    Delco Module 52479971 CJ2 Dual Zone AC 158756
    GM wants = $220.00
    GMpartsdirect.com = $114.52
    Rockauto.com = $116.79
    Ebay new = $99.00
    But i just found a new one for $40.00.
    Worth a try.
    Out of curiosity. Does anyone here have dual zone auto air in their cars?
  20. #20 Re: Another Blower Motor Question.
    SE Level Member lorenzojay's Avatar
    Roseville Mi
    Cant you bypass the resistor and put an in line variable speed knob that regulates the power?
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. blower motor
    By Chleby in forum General Tech Discussion
    Last Post: 09-13-2017, 04:00 PM
  3. The Old and The New, Blower Motor Resistor
    Last Post: 01-29-2008, 12:31 PM
  4. 97 blower motor wont fit a 99
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-01-2008, 12:14 AM
