Hey guys,
As all of you may or may not know I am new to the Grand Prix so I am uncertain if all is well or not so I thought I would ask away.
2008 Grand Prix:
I noticed the temp gauge needle will not go any higher than halfway between the 1/4 & 1/2 mark. The car seems to take longer to heat up compared to other cars I have had in the past & also noticed that unless I have the heat set at higher than 80 degrees it doesn't seem to get very hot in the car.
Didn't know if this is a sign of an issue or normal. I'm used to setting the heat to about 72 & being comfortable & when I have the heat set at the same setting the air feels cool coming out of the vents.
Thanks in advance!![]()
