Thread: what is that rattle when starting?
Results 1 to 9 of 9
  1. #1 what is that rattle when starting?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    I know problem after problem.Im sure this can be worked out too.Ive noticed most times car starts up fine,strong.Dont have to give it any gas and only half turn the key.So for the most part satisfied.I have noticed that on occassion when starting youll get this rattle,like something is spinning.Any ideas?
  2. #2 Re: what is that rattle when starting?
    Jun 2011
    Detroit, MI
    Well has the car been sitting over night? If so then it probably just our loud 3.8. Or it might be your a/c compressor or something of the sort. Videos help.
    iLoveSpade
  3. #3 Re: what is that rattle when starting?
    check your exhaust hangers, i was missing 2 and it was rattling pretty bad when i started it up.
    fyi: peppys and auto zone wanted 5 bucks a pop for the fat little O rings that holds the pipe up, i found them at a small mom and pop auto parts store for 1 buck each, some stores are just out of their minds i think with their prices.
  4. #4 Re: what is that rattle when starting?
    Florida
    OOHHH...pick me!
    Ima go with a bad tensioner/worn tensioner!
    They tend to sound like a chatter on start-up with the belt torquing them
  5. #5 Re: what is that rattle when starting?
    Nov 2011
    portsmouth,virginia
    Thank you all for your opinions.I do tend to think it may be what machinegunsquid mentioned.Its definately coming from under the hood.Im wondering however when you say tensioner are you talking timing chain tensioner?(i assume all cars have a timing chain?)My xterra had two tensioners that went bad right after the bad timing chain had to be replaced(truck was only 3 years old at the time)
  6. #6 Re: what is that rattle when starting?
    he would have been talking about the belt tensioner, remove the belts and spin the pulleys, check the tensioner marks to see if they are still good and lining up.
    they are the pulleys you need to turn to remove the belts, its a 14 mm socket i think.
  7. #7 Re: what is that rattle when starting?
    Florida
    Our cars have a timing chain Dampener/Damper.
    It's kind of like a tensioner, does the same job, just a different style.
    And no, I mean the tensioners for the serpentine belt, and the supercharger belt (if you have a GTP)
    Just pop the hood, and have someone start the car, while you look. It's really easy to see if they are chattering. They'll rock back and forth, and the actual noise is caused by the tensioner hitting the stop (fully disengaged)
  8. #8 Re: what is that rattle when starting?
    GT Level Member RegalGS98s's Avatar
    NJ
    Is it a GTP? Surprised no one's mentioned supercharger rattle. My Regal would make a rattle noise from the supercharger for the first 15-20 seconds of it running.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  9. #9 Re: what is that rattle when starting?
    Never Never Land
    Try starting the car while holding the brake? Some cars the ABS makes noise when you start it...like mine. If I start it without holding the brake it makes noise immediately. If I hold the brake and start it, it doesnt make any noise until I let the brake back out.
  1. Rear End Rattle
    By slydoggy38 in forum Introductions/Noob Questions
    Last Post: 06-11-2011, 12:40 PM
  2. little bit of rattle and a tps?
    By gpgt04 in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2010, 07:47 PM
  3. HUD Rattle
    By mseefried in forum General Tech Discussion
    Last Post: 10-09-2010, 11:53 AM
  4. rattle cans
    By NomeCrusher in forum Detailing Tips and Tricks
    Last Post: 08-14-2009, 04:27 PM
  5. rattle on accelleration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:31 PM
