Thread: HELP: My Fuel Filter Won't Come Off
Results 1 to 11 of 11
  1. #1 HELP: My Fuel Filter Won't Come Off
    Topeka, KS
    As the title says. It just won't come off. It's rusted and just won't budge. And.... Now it's rounded off on the flare nut.
    I've Tried...
    * Line Wrenches
    * Vice Grips
    * Channel Locks
    * PB Blaster
    * Seafoam Deep Creep
    * Another Friend Trying It
    I need to get it replaced before I get re-tuned.
    Any suggestions would be greatly appreciated!
    Thanks,
    Ryan
  2. #2 Re: HELP: My Fuel Filter Won't Come Off
    Feb 2009
    flintnasty MI
    heat and vicegrips...
  3. #3 Re: HELP: My Fuel Filter Won't Come Off
    Florida
    YES OPEN FLAME !!!!! burn the car and replace car and filter.
    sorry.... worst case... go to a junk yard find a car where you can remove the filter and then drop the fuel tank and swap the line. if you really cant remove it its worth swapping the line vs cutting it and piecing it together with fittings
  4. #4 Re: HELP: My Fuel Filter Won't Come Off
    Feb 2009
    flintnasty MI
    It is not at all uncommon to use heat to get a fuel filter apart.. You typically should not be holding flame on it as you are loosening it, but fuel is not flamable on the hot metal.
  5. #5 Re: HELP: My Fuel Filter Won't Come Off
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    or cut the line, then get a splice from the autoparts store. thats what i had to do.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  6. #6 Re: HELP: My Fuel Filter Won't Come Off
    Akron Ohio
    Twist the filter not the line.
  7. #7 Re: HELP: My Fuel Filter Won't Come Off
    ^^^^^^^^^X2
  8. #8 Re: HELP: My Fuel Filter Won't Come Off
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Like joshsgtp said you could try twisting the filter. just put the vice grip on the flare nut as tight as you possibly can and put ur wrench on the filter and twist it off. otherwise cut it and put a new piece on there. "piecing" it is actually not bad if you know how to flare. or you can use compression fittings. OOOORRRRR you can get real ghetto and use rubber hose and two clamps lol
  9. #9 Re: HELP: My Fuel Filter Won't Come Off
    Jun 2011
    Detroit, MI
    I HAD THE SAME PROBLEM: I took it to the shop and they got it off in 5 mins with a torch.
    And its doesn't always work to just "twist the filter".
    iLoveSpade
  10. #10 Re: HELP: My Fuel Filter Won't Come Off
    Charles City, IA
    A shop really torched your fuel filter?>
    SMGPFC Two Nipple General
  11. #11 Re: HELP: My Fuel Filter Won't Come Off
    Jun 2011
    Detroit, MI
    Yes, the nut was rounded, they torched it for a minute or so, and worked it off pretty quickly.
    iLoveSpade
  1. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  2. Fuel Filter!!
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2011, 12:55 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
