Thread: Wierd things happening, I need help
Results 1 to 4 of 4
  1. #1 Wierd things happening, I need help
    Sep 2011
    South Central PA
    Yesterday I replaced the top of door weatherstrip on my 2000 gtp. Which meant I had to pull the door panel off. Not all the way off but enough. Later on I come to a stop sign and my radio shuts off. Also my door locks do not lock and my power seat does not work or have heat. When I press the lock and unlock it clicks but does not do anything. My windows and mirrors work. It didnt have these problems right after I was finished with the weatherstripping. I went several places and logged probably 40 miles and it just happened. I checked the fuses and even replaced them to see if that was the problem but that did not solve anything. Could anyone help me, what is going on with my car? Thank you
    2000 Grand Prix GTP Daytona 500
    WBS PCM, 3.5 Pulley, 3'' DP into Magnaflow Hi Flow Cat, Powerlog, No resonator, Wizaraid Intake, ZZP Wires, AL 104's, 180 Stat, Poly Dogbone Bushings, Optima Yellow top battery
  2. #2 Re: Wierd things happening, I need help
    Omaha, NE
    I would say to check your grounds first, but it sounds like you probably nicked a wire. Did you have a knife/ or screwdriver anywhere near wires? Did you let the door panel hang?
  3. #3 Re: Wierd things happening, I need help
    Sep 2011
    South Central PA
    I didn't use a knife or anything and I sort of left it hang, it wasnt disconnected off the top at the window. Just the clips were popped loose
  4. #4 Re: Wierd things happening, I need help
    Sep 2011
    South Central PA
    UPDATE: I found a diagram of the fuse panel. All of row G is out. Hooked a test light up to it and all of row G didnt have power. The diagram can be seen here:
    Bad horn= service engine soon? - Grand Prix Net
    Could row G share a common ground? Or Is there something else I am missing?
  1. What would you do if this was happening
    By nyydmb12 in forum Off Topic Discussion
    Last Post: 07-02-2010, 02:16 AM
  2. What's happening!
    By rechristel in forum Introductions/Noob Questions
    Last Post: 06-28-2010, 02:20 PM
  3. 0.0000001 chance of this happening
    By bronzemist02 in forum Off Topic Discussion
    Last Post: 01-21-2010, 09:54 PM
  4. QUESTION about something wierd happening.
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 11:46 PM
  5. Replies: 1
    Last Post: 03-11-2009, 05:19 PM
