Thread: Dirt getting flung under hood from belt
Results 1 to 8 of 8
  1. #1 Dirt getting flung under hood from belt
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Does anybody know why this is happening? Is it normal? I cleaned the area once before and it seems to be coming back. Its right above the belt for the supercharger.
  2. #2 Re: Dirt getting flung under hood from belt
    Oct 2011
    Toledo, OH
    Check your superchargers oil. I think this is the snout bearings leaking?
    7"
  3. #3 Re: Dirt getting flung under hood from belt
    Oct 2011
    New Jersey
    Well i know for a fact i need to change the coupler and supercharger oil soon
  4. #4 Re: Dirt getting flung under hood from belt
    water, and dirt and mud or whatever will hit the belt and sling onto the hood.
  5. #5 Re: Dirt getting flung under hood from belt
    utah
    Cv axle time
  6. #6 Re: Dirt getting flung under hood from belt
    could be the water pump leaking, i had a nice strip like that when my pump went.
  7. #7 Re: Dirt getting flung under hood from belt
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i agree about the axles. i'm having the same issue. but i'm getting clumps of grease on my hood.
  8. #8 Re: Dirt getting flung under hood from belt
  1. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  2. dirt cheap!!
    Last Post: 03-07-2009, 01:59 AM
  3. dirt buildup so fast
    By tod1d in forum Visual/Body Modifications
    Last Post: 08-07-2008, 01:23 PM
