Thread: Door panel clips
Results 1 to 11 of 11
  1. #1 Door panel clips
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Anybody know of a good door panel clip/fastener? I bought two packs of the Dorman brand GM panel clips at autozone and they break in the process of installing.
  2. #2 Re: Door panel clips
    Are you lining them up before you push on the panel?
  3. #3 Re: Door panel clips
    Jul 2011
    Eastern Idaho
    Yes, lined up. They are so brittle sometimes they break just putting them in the door panel. They mainly break where the clip fits in the panel which is fine as long as it happens when taking the panel off because it will save the panel.
  4. #4 Re: Door panel clips
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    I would take them back to autozone... They should work fine... try advance instead... autozone is poop.
  5. #5 Re: Door panel clips
    Kansas
    Advanced is going to carry the exact same thing as Autozone.... Dorman.
  6. #6 Re: Door panel clips
    Oct 2011
    Reading PA
    Quote Originally Posted by NegativeOne13 View Post
    Obviously.... Just saying in my opinion, advance is better... Cheaper prices, always have parts i need in stock for the most part, and the parts ive purchased from there are never defective or ****ty quality..
  7. #7 Re: Door panel clips
    Ocala, FL
    I used dorman panel retainers to install my trunk lid mat, none of them broke at all..
    Maybe it was the ones you got?
  8. #8 Re: Door panel clips
    Bunnell, FL
    mine just bend when the get pissy
    I'm a Sex Offender
  9. #9 Re: Door panel clips
    Dec 2008
    chicago
    go to clipsandfasteners.com and type in the part # 10153057 for 97 or 10408480 for 98-02 good quality stuf,I buy all my clips from there.
  10. #10 Re: Door panel clips
    GTP Level Member
    springfield IL
    ^^^^^^. Yes!!!! This is the place to buy from! Alot cheaper than autokrap
    I've never had any problems with them breaking...??? Had my door panels off atleast 6times
  11. #11 Re: Door panel clips
    SE Level Member Wraith888's Avatar
    Twin Cities
    I went to Autozone and had the same experience with the ones that they sold - I tried to slide the heads of the clips into the door panel and they snapped right off. The ones that were factory seemed aged, yet far more pliable than the Autozone ones - the new ones were breaking left and right. Are the clipsandfasteners ones more pliable?
    Thanks!
  1. Door Clips!
    By Wrongwayislost77 in forum General Tech Discussion
    Last Post: 07-04-2011, 03:26 PM
  2. GTP lower door moulding clips
    By Regalgs98 in forum General Tech Discussion
    Last Post: 03-22-2011, 11:09 AM
  3. What store can i find door panel clips at?
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 07:54 PM
  4. Door panel
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 02:26 PM
